Results 11 to 12 of 12
    using sea foam in the carb you think will stop the piston knock ?
    my guess is this is a lubrication issue. the marvel mstery oil is safe and compatible in the oil when used in the amount I previously suggested.
    sea foam is a solvent. this is for rapid cleaning and must be used very carefully to avoid engine damage.
    I know nothing about the 5.7L carb. engines. I know on my 5.3L fuel injected, Engine Knock is typically created by a few things:
    • Low oil (it has to be really low)
    • Bad Spark plug/spark plug cable
    • Knock sensors are bad ( the 5.3L has 2)
    • (Specifically to the 5.3L....) the 5.3L has issues with the lifters getting gummed up bad over the life of the engine and they will create a knocking sound when the engine is cold.
    Sea foam will help clean the gummed up stuff on the lifters to a certain point. and clean some of gunk on the spark plugs. Knock sensors typically just have to be replaced :-(.
  1. 06 chevy silverado 5.3L making weird tappin noise
    By jobrien836 in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 03-27-2012, 12:51 PM
  2. First offender making noise about Watertown?s new noise ordinance
    By Enkeiavalanche in forum Audio, Video & Gadget Tech
    Last Post: 09-15-2011, 08:25 PM
  3. 5.3l knocking and other noise - VIDEO
    By Lifted_Bowtie in forum GM Powertrain
    Last Post: 06-25-2011, 11:49 PM
  4. Knocking noise need help
    By 96BlackSilverado in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 01-12-2010, 03:22 PM
  5. Front end knocking noise.
    By paul0451 in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 04-02-2009, 10:04 AM
