    Default intake manifold gasket priblem
    hi there i am new to the club i have 98 chevy k1500 with the vortec 350 that has 212000 miles on it the last week i started losing antifreze
    i thought i had a rad leak .the other day the truck idle funny so i check the oil & it was part antifreze .Do i have a bad intake gasket or did i blow a head gasket the truck was not over heated any ideals?
    thanks crazyforgms
    You have a very major leak if water is in the oil.... Water in the oil can mean the end of an engine if you don't fix it immediately. It could be either. You may have to remove the head and intake. You will also have to drain the oil and coolant. You will also have to complacently flush the oil to try to get the water out.
    thanks for replying i am not driveing it i drain the oil & had the truck towed to the shop i bought it from i hope it is not a head gasket
    All they have to do is check the compression of each cylinder. Still it is gonna be expensive to fix.
    Any funny color smoke coming from the exhaust when it was running??
    00 Chevy Tahoe LT, 5.3 4x4
    monday my buddy & i took the intake off my truck .after we removed the intake you could see were the gasket failed ,we clean the inside of the engine replace the gasket & reinstalled the intake the truck runs like new thanks for the help
    happy motoring
    Quote Originally Posted by crazyforgms View Post
    happy motoring
    I hope you spent the extra money and got the better, upgraded gasket..
    Happy to hear your truck is fixed. You should try to do a write up on it.
  1. Intake Manifold Gasket decision
    By BulldogZ71 in forum Chevy SUV & Crossover Tech Forum
    Last: 09-06-2012, 12:02 AM
  2. Leaking Intake Manifold Gasket
    By JLNelsen in forum General Chevy & GM Tech Questions
    Last: 01-18-2011, 10:17 AM
  3. What intake manifold gasket to get? !
    By Dr_Zero in forum GM Powertrain
    Last: 05-29-2010, 02:56 PM
  4. Intake Manifold Gasket Woes
    By 97BurbanSLT in forum General Chevy & GM Tech Questions
    Last: 04-20-2009, 05:22 PM
  5. finished: intake manifold gasket [Expired Topic]
    By MrShorty in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 11-04-2006, 12:37 PM
