Results 1 to 9 of 9
    Sr. Mechanic
    Jun 2011
    Tuscaloosa, AL
    Default Headlight and fog
    I remember hearing at one time a way to make the fog lights stay on with the HI beams, but now I can't find where. Has anyone done this or know how to?
    2004 GMC Sierra SLT 6.0L 4x4
    UWS Low Profile toolbox 10% tint front and over stock back tint
    AirAid MIT and K&N airfilter
    BlackBear Performance
    there is a thread floating around on here that shows you how to do it. forget what its called. some sort of diode links between the relays for the low and high beams.
    Alex
    Ext Cab 4wd LT
    Check out my garage
    http://www.NStarWindow.com
    Sr. Mechanic
    Jun 2011
    Tuscaloosa, AL
    Thanks for link it'll give me a small project to do
    I am going to stop at radio shack in the morning and pick up some diodes. My fogs are pointless (can't even tell they are on) I am interested in having the lows run with the highs. Even I can stick a diode in a hole!!
    Definitely a great mod, $5 and about ten minutes (if you go slow).
    Pikey- I have heard that you can run the hi beam bulbs in the fogs, I'm waiting for one of mine to burn out until I go for it. Maybe then you will be able to tell when they are on.
    Ext Cab 4wd LT
    Check out my garage
    Quote Originally Posted by FrigginNoodles View Post
    not in my fogs. they take some weird size bulb
    Too bad, doing the lows and hi's together will help you out then.
    Ext Cab 4wd LT
    Check out my garage
    Will this work on the old style 99 Suburbans?
    Thanks,
    Al
  1. Need info on swapping '90's single headlight grille to composite headlight.
    By Gryphon in forum General Chevy & GM Tech Questions
    Last Post: 07-08-2012, 07:15 PM
  2. help after headlight mod
    By bowtie afair in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 05-31-2010, 12:59 AM
  3. Headlight help
    By lsutoms in forum Chevy Truck Accessories
    Last Post: 12-23-2009, 11:15 PM
  4. NBS Headlight Kit
    By CornhuskerChevy in forum Chevy Truck Accessories
    Last Post: 08-30-2009, 08:26 PM
  5. FS: Headlight
    By invader in forum General Classifieds
    Last Post: 12-17-2007, 05:29 PM
