View Poll Results: How Often do You Use 4Lo?
Voters
28. You may not vote on this poll
  • Never. (Literally never/super rarely)
    4 14.29%
  • Once in a while. (max once to twice a year)
    11 39.29%
  • More often than most. (3+ times a year consistently)
    8 28.57%
  • All the time. (once a month or multiple times a month)
    4 14.29%
  • What's 4Lo? Or not a 4wd vehicle.
    1 3.57%
Results 1 to 10 of 25
    Default How Often do You Use 4wd Low?
    Moving my truck in our normal snow fall shuffle the roads are so icy that I needed 4Lo to back up into my normal parking spot.
    I'm just wondering how often do you guys use your 4Lo, the torquest the truck can get.
    only use it when i feel the need to have finesse when moving large objects like campers. otherwise i feel 4hi is the way to go especially in snow. less chance of spinning that way.
    I only put it in 4 low once in a while. I rarely need it, if ever. I just do it to make sure that the tcase remembers what it is supposed to do. I used to put it in 4 low in my 95 all the time at the sand dunes. I had a posilok 4 actuator so I would put it in 4 low and not actuate the front diff, so I would have 2 low. I had all the torque I needed to get up steep dunes and still had the turning radius of being in 2wd.
    My Chevy doesnt have a transfer case so never, but the Tacoma is almost always locked in low, similiar to Pikey I did a twin stick conversion on it so I can run low range in 2wd.
    Like Pikey, I will select 4LOW to "exercise" (I like that word) the t-case, but I rarely use it. I haven't used it in this truck and I don't remember using it in the previous truck (however, I doubt if I would buy a truck without the 2 speed box). I did use it in the '96 Blazer, for climbing gravel pit walls and steep logging roads.
    As Pikey and RayVoy said, i just put in there sometimes to keep it known. Everytime ive been offroad, i have only ran 2wd at silver lake sand dunes.
    2010 Silverado Z71
    Kyle-USAF-MI/VA
    "Fueled by Haters"
    TCS front box 7"-9" set at 8.5" | FTS coilovers(blue coil) with resis and FTS shocks with resis| 20" Fuel Off-Road Revolver Rims | 35x12.50 Nitto Trail Grapplers | Halo Projector Head Lights by Recon- Black | Led Taillights by Recon- Smoked | Dumped Straight pipe | Volant CAI | Ranch Hand Front Bumper | DiabloSport Trinity Programmer | Tow Mirrors with Turn Signal | Cervinis Ram-Air hood | 4.56 USA gears with tru trac locker | Longshot Lighting 6000k 55w low beam and 6000k 35w fogs HIDs | 7" lift leaf spring | Blue TCS traction bars
    Future Mods: Long tube headers
    | Custom tune | Cam | Stall Converter
    Well I proved I need new tires. After going out and staying in 2wd most of the way the rear lost grip a few times in intersections.... And even in low I couldn't get beck to my parking spot because it is just to icy and slippery.
    Well we got a little white stuff last night soo I ight put it in just to Lube up the gears.. But other then that 4w Auto does just fine or even 2wd with the locker is fine in this snow..Click image for larger version.
  1. Info on MAF's and why to clean them offten
    By Enkeiavalanche in forum Maintenance & Upkeep
    Last Post: 02-20-2012, 04:21 PM
  2. MAFS How offten do you clean it? Or don't you?
    Last Post: 06-01-2011, 11:49 AM
  3. MAFS How offten do you clean it? Or don't you?
    By Enkeiavalanche in forum General Chevy & GM Tech Questions
    Last Post: 04-14-2010, 11:13 PM
