Results 1 to 10 of 11
    Default Adding factory remote start to a 2012 Silverado?
    Can you add the factory remote start to the 2012 Silverado without much hassle?
    Is it as simple as buying new key fobs? Or is there something that the dealer has to actually install?
    If so, anyone have any part #'s or literature for this?
    2012 Silverado 1500
    2004 Silverado 1500 (SOLD): http://tinyurl.com/JRD761sTruck
    1977 Silverado C20:
    http://tinyurl.com/JRD761-1977-C20
    I believe there is a module/software that must be installed to have remote start. I would call your local dealer and ask them. They will also give you any part numbers you need.
    Quote Originally Posted by JRD761 View Post
    If you go to the Link Below.....it will answer your Questions Regarding the Installing of the Factory Remote Start, on your 2012" Silverado.
    Link,
    http://www.gmtruckclub.com/forum/sho...y+Remote+start
    The post to pay attention to, is #12, written by Mike, @99'HEARTBEAT
    I just had Rod Hatfield Chev in Lexington KY do this for my truck. If your truck is already prepped it is a "kit" which basically consists of two new remotes that have the starter on them and then they program the remotes and your truck.
    If it does not I think there is a bit more to it. For me having a dealership get the kit (key fobs) and install/program was about $300 total for my duramax.
    ...being able to start the truck with my cell phone via the OnStar app - REALLY AWESOME! Truck is warmed up when I am ready to leave work.
    You can get a nice remote start that will use all the factory features via the databus interface. My heated seats and rear defrost turn on automatically if it is below a certain temp. They cost around $200 installed. It is cheaper than the dealer and you have added range. Only option that you do not get is the onstar app that @E_HILLMAN mentioned. There are remote start companies that can do that also. I have a friend that turns his truck on from his cell phone with an aftermarket starter.
    Nov 2011
    Central Illinois
    What remote start system do you have?
    2012 Silverado 1500 LT 4X4
    2003 Suburban LT 2500 6.0L
    http://www.crimestopper.com/Templates/ps04-g3.html
    I have had others
    http://www.onlinecarstereo.com/CarAu...FehDMgodWGYAlQ
    As long as they use the databus interface (which is $80) then most of them will activate the factory included features.
    Nov 2011
    Central Illinois
    I have had others
    How do you know they use the databus interface? "Databus" isn't mentioned in any of the specs.
  1. Chevy Traverse Keyless Entry Remotes ~ Adding Remote Start & Power Liftgate
    By ChevyFan in forum Chevy Traverse Forum (GMC Acadia, Buick Enclave)
    Last: 12-27-2012, 04:43 PM
  2. 2012 silverado remote start
    By tonkarepo in forum General Chevy & GM Tech Questions
    Last: 09-20-2012, 02:57 PM
  3. Adding remote start - Chevy Remote 2-way [Expired Topic]
    By jlenko in forum Chevy Equinox Forum (GMC Terrain)
    Last: 07-12-2010, 11:20 AM
  4. Adding a remote start to a 2006 Sierra
    By aedragster1 in forum Audio, Video & Gadget Tech
    Last: 05-13-2010, 01:16 PM
  5. need help with adding remote start to my truck
    By 08crewcabhd in forum General Chevy & GM Tech Questions
    Last: 03-15-2010, 11:45 AM
