    Default Shifting into 4W drive
    Need advice from you Chevy owners...
    the floor mounted shifter is kind of stiff shifting into 4WD.
    (I'm assuming you can shift on the fly ?)
    any trick with this, or just put some muscle in it ?
    Thanks
    What year truck? I suggest that you crawl under the truck and spray the shift linkage at the transfercase down with some PBlaster. It should make a world of difference? You can shift between 4wd high and 2wd while on the fly. For 4 low you usually need to be rolling under 5mph with the trans in neutral, then shift into 4 low or back to 2wd from 4 low. I would check your manual for your truck and see what it says about 4 low
    Thanks, will definitely have a look at that
  1. converting 2 whel drive to 4 wheel drive
    By jdaugherty3 in forum GM Powertrain
    Last Post: 11-24-2013, 07:15 AM
  2. 4L60E problem. Strange shifting into drive. Coming out of OD.
    By freightshaker in forum GM Powertrain
    Last Post: 04-05-2012, 09:49 AM
    Last Post: 03-21-2012, 01:26 PM
  4. When shifting into reverse at higher idle can feel and hear loud 'CLANK' drive makes
    By BobEhud in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 09-21-2011, 03:17 PM
  5. Transfer Case Shifting Motor Not Shifting after Installation
    By derickheggie in forum General Chevy & GM Tech Questions
    Last Post: 01-30-2011, 10:52 PM
