Results 1 to 9 of 9
    Default 97 gmc 4.3 electical problems
    i have a 97 gmc 4x4.have replace motor and bout all the sensors.now having an electrical problem.some sensors test good with test light and some dont....really need some help please
    I think that we may need some more information! What sensors are testing bad? How are you testing them with a light? Not all sensors will test "ok" with a test light. What codes are you getting? The codes could help track down the issue.
    x2. we need to know what your issue is
    Welcome to the club, it's good to have you here.
    mfleetwood's Avatar
    Jul 2010
    Denver, CO
    I moved your thread to the correct forum section and enhanced your thread title so that it more describes the category of problem you are having.
    Welcome to the Club and good luck in getting your issues solved.
    TIRES:
    BFG All Terrain KO 315/70/17
    getting codes for oxygen sensor and catalyst not ready,truck runs great untill its warmed up.cruising around 60 mph then it jerks
    You replaced the o2 sensors?
    Current:
    Future:
    US Navy Sailor :sign0011:
    When cold, the PCM uses a programmed set of fuel/air mix instruction tables (open loop). When the engine gets warm, the PCM switches to the O2 sensors to tell the PCM the ratio that is needed (closed loop).
    If it runs "bad" when warm, you probably need new O2 sensors (just the front ones, the rears are to test the cat).
    The heater circuit may be bad or crossed signal wires, scan it when running bad and go to data and tell us the voltage of the upstream (1/1,1/2) sensors. They should bounce up and down consistantly. You can use a light to test the heater circuit but DO NOT , repeat DO NOT SHORT THE HEATING AND SENSOR CIRCUITS, WILL FRY THE COMPUTER! What i use is a low beam headlight with socket to test both power and load test the wires, if it starts bright then dims there is a bad connection somewhere, no light no power.
    01' 1500 LT Z71 ECSB 5.3L
  1. 2007 Suburban Instrument Panel Goes Out / Electical Problem
    By tomtina1 in forum GM Electrical Tech
    Last Post: 09-30-2010, 05:19 PM
  2. few questions, electical on 75 burban 454
    By bldeagle10 in forum General Chevy & GM Tech Questions
    Last Post: 12-26-2009, 07:13 PM
  3. Electical issues after installing CB
    By Dementia in forum General Chevy & GM Tech Questions
    Last Post: 06-30-2009, 08:16 PM
  4. 09 Suburban electical question
    By mballes in forum Audio, Video & Gadget Tech
    Last Post: 05-26-2009, 03:12 PM
  5. moisture in electical system
    By Jamesbo in forum General Chevy & GM Tech Questions
    Last Post: 01-07-2009, 10:20 AM
