Results 1 to 9 of 9
    Default 97 gmc 4.3 electical problems
    i have a 97 gmc 4x4.have replace motor and bout all the sensors.now having an electrical problem.some sensors test good with test light and some dont....really need some help please
    I think that we may need some more information! What sensors are testing bad? How are you testing them with a light? Not all sensors will test "ok" with a test light. What codes are you getting? The codes could help track down the issue.
    1995 Silverado 4x4 (Sold)
    Sr. Mechanic
    Aug 2010
    eas' bum fuk, maine
    x2. we need to know what your issue is
    Welcome to the club, it's good to have you here.
    2002 Chevrolet Silverado Ext Cab 5.3 Liter / Automatic:
    Current Modifications:
    • Edge CS programmer w/Pod
    • K&N intake
    • Magnaflow exhaust
    • 2005 Tahoe grill with Grillcraft Stainless Steel SW series wire mesh insert
    • 2005 Tahoe Z71 valance under bumper with round fog lights
    • Recon LED Daytime Running Lights
    • Third Brake light is LED by IPCW
    • Tail lights are Spyder
    • Headlights are TYC
    • Front blinkers are Anzo LED
    • 6000K HIDs in headlights high beam, low beam and fog lights
    • LEDs everywhere else inside and out
    • Rear lights wired to work like the new Silverado with 4 tail lights, blinkers and brakes
    • Lowered 2" in the rear
    • Genuine GM 20" chrome wheels with 285-50-20 tires
    • Drilled and slotted rotors
    • Calipers painted to match
    • Kenwood DNX 6160 radio with Bluetooth, GPS, DVD, iPod, Back up Camera and satellite radio
    • 2 Cerwin vega amps "1400 watts total"
    • 2 - 10" Kicker subs in custom box under back seat.
    • 4 Infinity main speakers and 2 PB tweeters on front post
    • New custom paint job, Red Fire on Charcoal Gray
    "There's no fun in playing safe or by the rules, but it's not fun being hit by a semi-truck either."
    Jul 2010
    Denver, CO
    I moved your thread to the correct forum section and enhanced your thread title so that it more describes the category of problem you are having.
    Welcome to the Club and good luck in getting your issues solved.
    TIRES:
    BFG All Terrain 315/70/17
    getting codes for oxygen sensor and catalyst not ready,truck runs great untill its warmed up.cruising around 60 mph then it jerks
    You replaced the o2 sensors?
    Current:
    1999 GMC Sierra SLT Z71 | 5.3 Vortec | Spectre Cold Air Intake | TransDapt TBS | Hypertech 30005 Tune | 2005 Chevy Tails | Clear No Name Headlights | AWS Bug Shield | 265/75/16 Mastercraft Courser A/T | "Ghetto" painted tailgate | Boss HD Speakers | 2005 Overhead Console | Dual Thrush Turbo Mufflers | Ye Olde Toolbox "borrowed" from ex-brother in law
    Future:
    3 inch lift kit | 33 inch A/Ts | 4.10 gears | Bigger Alternator | Electric Fans | Oil/Trans Fluid cooler with fan | Custom Tune | Headers | Re-done exhaust | Paint | Interior Restoration/upgrade with newer model stuff | Newer GMC front cap | Window Visors (In channel) | Tint | Low-Profile Tool Box | LEDs throughout stock cab locations | And whatever is spurr of the moment
    US Navy Sailor :sign0011:
    When cold, the PCM uses a programmed set of fuel/air mix instruction tables (open loop). When the engine gets warm, the PCM switches to the O2 sensors to tell the PCM the ratio that is needed (closed loop).
    If it runs "bad" when warm, you probably need new O2 sensors (just the front ones, the rears are to test the cat).
    The heater circuit may be bad or crossed signal wires, scan it when running bad and go to data and tell us the voltage of the upstream (1/1,1/2) sensors. They should bounce up and down consistantly. You can use a light to test the heater circuit but DO NOT , repeat DO NOT SHORT THE HEATING AND SENSOR CIRCUITS, WILL FRY THE COMPUTER! What i use is a low beam headlight with socket to test both power and load test the wires, if it starts bright then dims there is a bad connection somewhere, no light no power.
    01' 1500 LT Z71 ECSB 5.3L
  1. 2007 Suburban Instrument Panel Goes Out / Electical Problem
    By tomtina1 in forum GM Electrical Tech
    Last Post: 09-30-2010, 05:19 PM
  2. few questions, electical on 75 burban 454
    By bldeagle10 in forum General Chevy & GM Tech
    Last Post: 12-26-2009, 07:13 PM
  3. Electical issues after installing CB
    By Dementia in forum General Chevy & GM Tech
    Last Post: 06-30-2009, 08:16 PM
  4. 09 Suburban electical question
    By mballes in forum Audio, Video & Gadget Tech
    Last Post: 05-26-2009, 03:12 PM
  5. moisture in electical system
    By Jamesbo in forum General Chevy & GM Tech
    Last Post: 01-07-2009, 10:20 AM
