Results 1 to 2 of 2
    Cool 2000 Siverado 4.3 No Heat
    Flushing the cooling system and it was full of crude dirt looking junk, The engine temp comes to temp 209# Top heater hose gets hot and lower stays cold, Just bought the truck, did not try the heater before begining flush. What would cause the hot water from going to the heater, Fan works and so does the A/C, new cabin air filter. Does the coolant to the heater core have a soleinode on it that would block the coolant to the heater core, or is my heater core pluged up ? If so what is a back flush and how do I do it.. Thanks Again Doc
    I found the back flush on youtube, will give it a try . Thanks Doc
    Ok, no solenoid, the HVAC unit uses a temp door to direct air through the heater core, or the ac evaporator core.
    You could have sufficient dirt in the line to plug it, but I suspect it is just air. Try removing the lower hose and letting the coolant flow through the core.
  1. Front heat blowing cold on 2000 Yukon
    By Maxx1500 in forum Chevy SUV & Crossover Tech Forum
    Last Post: 01-22-2013, 02:05 PM
  2. 2000 Siverado 4.3 coolent flush ?
    By HDDOC in forum Maintenance & Upkeep
    Last Post: 01-04-2013, 08:44 AM
  3. heat prob with 95 Silverado heat then, no heat???need some help!PLZ
    By jteuban in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 11-20-2011, 09:34 PM
  4. 2000 Silverado stuck on heat
    By rduz in forum General Chevy & GM Tech Questions
    Last Post: 11-02-2010, 04:26 PM
  5. No heat up front, but heat in rear on '83 'burb
    By FUNFINDER in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 04-20-2009, 02:50 PM
