    Default Put in new steering column of 1978 truck but now starter does not kick over
    Hello everyone,
    My name is Tim I have a 1978 Silverado 4x4 and I am in the Army stationed at Ft Bliss, TX. My truck is a project truck, I have been working on the steering column, I put in a new procomp column and a new netural saftey switch. The dash lights and blinkers work but nothing is getting to the starter. Any help would be very helpful
    mfleetwood's Avatar
    Jul 2010
    Denver, CO
    Welcome to the Club!!!
    Unfortunately, I cannot help you with your problem, but I moved your thread and changed the title so that you will get faster and more responses vs the Member Introduction section. Good luck!
    TIRES:
    BFG All Terrain KO 315/70/17
    Welcome to the club Tim, it's great to have you here.
    Welcome to the GMTC.
    I'd start with that neutral safety switch - if it's not lined up, it may not let it start.
    Shift to neutral and try to start it (don't forget to set your brake) you can wiggle the shifter around and see if catches.
    Check the small guage ground wire from the battery to the fender - used to get me.
    Go Army!
    1999 Chevy K2500 Suburban 350
    Thanks everyone I tried just about everything. I got the truck off a young kid who installed his own radio. Needless to say the wiring is a little messed up. I am going to tackle the wiring when I have some time. Any ideas on a good harness, I looked at painless and amercian wire. Will post a pic when I get a chance.
    Did the truck work before the column change?
    I've heard both of those companies are good, but I don't have any first-hand knowledge. Have you checked out LMC? lmctruck.com
    It did work, but not like it should have. The column feel apart in my hands when I was driving, a little scary. All the wiring is all messed up, under the hood and everywhere else. I do not recommend buying anything from Procomp their customer services sucks. They do not return any calls or email. Just a heads up. I got a American wiring harness it was recommended by a couple of shops around the El Paso area. I looks pretty straight forward should be fun, I will post how easy or hard it was.
  1. 92 Steering column... Floor shift vs Column compatibility?
    By terryny in forum Chevy C/K Truck Forum
    Last Post: 09-28-2011, 06:10 PM
  2. new steering column truck won't start
    By mitchel1819 in forum GM Powertrain
    Last Post: 08-07-2011, 03:54 PM
  3. new steering column truck won't start
    Last Post: 08-06-2011, 05:15 AM
  4. 99-07 chevy silverado truck steering column bearing
    Last Post: 12-14-2010, 07:20 PM
  5. Replies: 1
    Last Post: 07-07-2008, 02:09 PM
