    Default HID Projectors for 07+ Avy/Tahoe/Suburban
    Does anyone know a good set of projector headlamp housings which can be used well with Xenon HID bulbs? I tried a set of the ones from Spyder Auto to no avail. They use H1 projectors, but it's a shallow projector, so the longer Xenon bulbs won't fit. Had to return them. Would like a design that's as similar to stock as possible (but not necessarily shiny chrome, and with smoked lens). Unfortunately, none of the manufacturers have enough info on their web sites, nor do the retailers, and getting answers through their support contacts doesn't seem to work very well either.
    Anzo seems to make a set that is similar enough to stock design to be nice, so would prefer them. Anyone used them with HID bulbs, or know of any other halo/projector housings that work well with Xenon HID builbs?
    Thanks.
    I am gonna suggest doing a retrofit. Most people who retrofit their stock housings use the Morimoto mini's and they use H1 bulbs. You can find the kit plus the relay for the H11 harness to ballast. Those Anzo, Spyder and all the other ebay ones are meant for halogen bulbs and not HID bulbs.
    The hardest part about a retrofit is getting the housings open. Most use a dremel. When I am ready to do my retrofit, I am going to be using a hot knife/soldering hot blade...whatever you wanna call it.
    But if you want to do those Anzo, Spyder type housings, get some Silverstar ultras or something as they will work better in those housings than HID's will
    I had these Click image for larger version.
ID:	46664 In my Truck for a while Light output was not that great but they did look cool. Halos were not as bright as I wanted But had a small crash and put my stocks back in with HID's in my fogs and Sylvania ZXE's in my Headlights.. Click image for larger version.
ID:	46665 Click image for larger version.
    a little late but.....
    from personal experience with aftermarket projectors, dont waste your money, do it right the first time with a proper retrofit....
    look up the morimotos, youd be surprised how easy it is! and did i mention it costs less too???
    2000 Chevrolet Silverado
    Powertrain:
    Performance:
    Airaid CAI
    Poweraid TB Spacer
    BLACKBEAR TUNED!!!
    Edge CS insight monitor
    4.10 gears
    Limited-slip differential
    LS-1 Dual Electric fans
    Corvette tranny servo swap
    Audio:
    Head Unit: Alpine
    Subs: 2-12" Kicker CVT's
    Tires/Wheels:
    16" PROCOMP 7089's
    Suspension:
    2" leveling kit
    3" Fabtech Spindle Lift Kit
    Lighting:
    FRONT
    35W HID Low Beams
    REAR
    Accessories:
    Hawk HPS Brake pads
    Powerslot Cryo brake rotors
    EGR in-channel window visors
  1. Projectors, and taillights
    By Scooter in forum Chevy Truck Accessories
    Last: 11-06-2011, 08:31 PM
  2. HID projectors vs. HID OEM reflector
    By reggiecab2000 in forum Lighting Discussion
    Last: 10-14-2010, 04:09 PM
  3. '99 Chevy Suburban HID and Projectors
    By rivera5130 in forum Chevy Truck Accessories
    Last: 02-10-2010, 11:57 AM
  4. Projectors and HID's
    By mashburn in forum Lighting Discussion
    Last: 08-20-2009, 10:53 PM
  5. Projectors and HID's
    By mashburn in forum Chevy Truck Accessories
