Thread: WTB Hp tuner
    Default WTB Hp tuner
    Anyone willing to part with their HP tuner equipment. I have an '05 Sierra 2500 8.1 and was going to start tuning. Thanks. Chris.
    Be careful buying a used tuner. If the seller does not remove the tune from their truck before sending it to you then it is worthless. I know a few people that have been screwed like that. We have have a vendor here that sells the Diablo tuners and custom tunes packaged to save you money. A few guys on here have his custom tunes and are very happy with it. Message @06MonteSS if you are interested.
    Thanks for the info. I have tuned a good many older GM's with the OBD1 and Tunerpro software. I like the convenience factor and the ability to make the quick retune if you change or modify something. I may just have to go with a new HPtuner instead..
    HP Tuners is a full tuning software suite, not a programmer like a diablosport, etc...
    big learning curve if you don't know what you're doing... and hptuners has a licensing scheme, so if you're buying it from someone else, you'll need to find out if they have any licences still available to use for tuning, need their cable that they got with it too I believe, since the cable/dongle is what contains the reg and licensing info...
    you'd be better off getting your own, brand new... then, make sure you read read read read.. cuz if you don't know what you're doing with tuning software, you can screw your **** up quick...
    06MonteSS
    2014 Camaro SS - 2SS, RS pkg., short-throw shifter, NPP perf. exhaust, BMR strut-tower brace, Cold Air Inductions cold air intake
  1. best tuner for my 06 5.7??
    By black98noma in forum Performance & Fuel
    Last: 09-11-2012, 01:21 AM
  2. HP Tuner .....
    By sstoner911 in forum Performance & Fuel
    Last: 05-22-2011, 11:09 PM
  3. Tuner for 08 LMM
    By blackedoutduramax in forum GM Diesel & DuraMax
    Last: 10-23-2010, 07:36 AM
  4. tuner
    By autohausfab in forum Performance & Fuel
    Last: 03-02-2009, 10:13 AM
  5. Best tuner?
    By Trask215 in forum Performance & Fuel
    Last: 09-12-2008, 09:52 AM
