    Sr. Apprentice black98noma's Avatar
    Dixon, IL
    Default oil pressure gauge acting up
    hey guys.. in my 2006 gmc seirra my oil pressure gauge just pegged to 80 one day last week. the truck runs fine,no check engine lights or any other warnings... just today it started sweeping from 0 to 80 randomly. like i said before, no warnings, lights or performance issues.. i know its just an electrical issue, but my question is where?? the stepper motor? the pressure switch?? wiring between the two?? ANY input is appreciated!!
    thanks!!
    2006 gmc sierra 1500 z71
    flowmaster 40 series cat-back system
    S&B cold air intake
    1970 chevy c10 350/290 crate engine
    dual flowmasters to dual outlet in front of the rear tires
    HAD a 99 Harley Sporster 1200
    after market paint job
    lotsa chrome
    screamin eagle pipes
    Most likely the stepper motor. Usually a bad sender just gives weird readings, not make it bounce around.
    Dixon, IL
    Thats kinda what i was thinkin... the motor is soldered on right??
    On the NBS and NNBS I think so, but not sure because I've never taken apart one of those clusters...
    Yes, they are soldered in. They can be bought for around $12 online. There are plenty of videos on youtube showing how to do it.
    Jr. Engineer
    Aug 2010
    eas' bum fuk, maine
    just to make sure, check your oil level.
    A new sending unit for the oil gauge is usually cheap but just cause I have delt with these gauges so much I would say its the stepper as well, but also if one is going the rest aren't far behind
    Hypertech III, K&N, true dual
    285/75/16
    ___________________________
    Jason
    Dixon, IL
    thanks for all your help so farguys!! so upon driving home from work tonight, the oil pressure needle was goin all over the place.. the scary (at least for me) thing is the "low oil pressure" message came across the info center.. is there any chance that the gauge going to zero is causing that mesage to come across, or are they seperate systems??
    ps.. oil level was 1/2 in the hash marks, which should be fine, but i added 1/2 qt just to be safe, no knocking,overheating due to lack of lubrication.. nothing phiscally wrong just wacky indications...
    Dixon, IL
    so bc i dont have time to mess around with this ne more, its off to the stealership...
    Dixon, IL
    so it turned out to be the oil pressure sensor. thanks for all your help guys!!!
  1. 1996-3500-oil pressure gauge and,fuel gauge spiked
    By vintageenterprises in forum General Chevy & GM Tech Questions
    Last: 12-21-2012, 11:02 AM
  2. Fuel gauge acting weird
    By msvx95 in forum Chevy Silverado Forum (GMC Sierra)
    Last: 11-13-2011, 11:49 AM
  3. oil pressure gauge acting funny
    By kawasaki_kid in forum General Chevy & GM Tech Questions
    Last: 01-25-2011, 03:12 PM
  4. Gas gauge acting erratic
    By rcrq500 in forum General Chevy & GM Tech Questions
    Last: 12-08-2008, 08:03 AM
  5. oil pressure gauge
    By GM_Guy in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 03-01-2007, 03:41 PM
