    Default Savana side door hinge broken!
    Ok - so I've sesarched the site and found great info on replacing the hinge pins (which needs done!) but the lower door hinge on the left side door on our 1999 GMC savana 3500 is broken. The actual hinge. Kinda sucks, actually. We have 6 kiddos and we use/will use that door. A lot.
    When I google door hinge all I seem to find are the pins - does anyone know where to get an actual replacement hinge?
    Thanks in advance!
    Travis
    Travis - Sparland, IL
    1999 GMC Savana 3500 15 passenger
    1997 GMC Suburban 2500
    http://www.gmpartsclub.com/parts-cat...k-and-hardware . I think that it is in the third diagram number 13 or 15 depending on what you need
    Pikey - thanks! Looks like a bigger job than I anticipated...but the door is about to fall off! As I've inspected more today I've actually got 3 broken hinges on the side doors. Ugh.
    Quote Originally Posted by Twgman View Post
    Sorry to hear that. That is not a super cheap fix. The hinges are pricey and if they are welded on it sucks even more.
    I had one "ear" break on mine and I had the local welding shop weld it back on for like $15 Worth a shot
    For us it was the door part of the hinge that broke. Local shop replaced the door (including paint) cheaper than it would have been to replace the hinge.
    I thought of looking for doors - but our local body shop gave me a great price and is willing to trade some pizza for payment! Van goes in next week!
  1. Need help with a door hinge part problem
    By gillespie85 in forum Chevy C/K Truck Forum
    Last Post: 01-21-2012, 07:54 PM
  2. Bent Tailgate Hinge, Passenger Side
    By Cyric in forum General Chevy & GM Tech Questions
    Last Post: 07-24-2010, 11:59 AM
  3. Replace Upper Door Hinge Drivers side
    By Marine88 in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 04-18-2010, 02:39 PM
  4. Squeaky door hinge
    By Trex in forum Chevy Colorado Forum (GMC Canyon)
    Last Post: 06-14-2009, 10:20 AM
  5. 99+ Silverado door hinge pin install?
    By mayo in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 06-05-2009, 04:20 PM
