Results 1 to 2 of 2
    Sr. Apprentice lube70's Avatar
    Northern NJ
    Default Need some insight...reduced engine power and SES light in 4wd Low
    OK guys and girls, I was down the Jersey shore doing dunes recovery and reconstruction and had my 06 silverado on the beach,. Reduced the tire pressure to 12 psi and was in 4wd hi. Got kinda stuck and went into 4wd low. Upon trying to get out of the sand, the engine light came on the DIC said reduced engine power. Car felt like it was running on 2 cylinders..No power. Swithced to 4wd hi and even 2wd and nothing. Thought I was stuck.
    Then shut truck off, started again and put in 4wd still nothing. Shut again and restarted in 4wd hi and all was ok.
    Is this a thing for 4wd low ? never encountered this. Guess it protects the drivetrain?
    Any info appreciated.
    Don
    2006 Chevy Silverado crew cab 1500
    Nope, not a thing in 4 low. I would take it to a parts store and have them read what code was set when the Engine light came on. There have been reported issues with the Throttle body and throttle body wiring for that year truck. It causes the reduced power message. Give the wire a pull at the throttle body connector and see if any of the runner stretches. If so you found your broken wire.
  1. Reduced Power Warning and Engine Check Light
    By caseyjones22 in forum GM Powertrain
    Last Post: 06-25-2013, 05:37 PM
  2. Reduced engine power
    By Chris_ce in forum GM Powertrain
    Last Post: 12-23-2011, 09:47 AM
  3. Reduced Engine Power
    By carson790 in forum General Chevy & GM Tech Questions
    Last Post: 03-12-2011, 11:26 AM
  4. Reduced engine power
    By stuntworks in forum GM Powertrain
    Last Post: 01-11-2010, 07:56 AM
  5. reduced engine power
    By bisskits in forum The Coffee Shop ~ Chit Chat
    Last Post: 09-29-2008, 08:54 AM
