    Default I found the fuel pressure regulator.
    I'm discouraged by the mess I found in there. I'm trying to attach some pics. I hope it works. There is no vacume line attached to the regulator and I'm not sure where one would come from if there was. The milky substance concerns me and I was hoping to get some input. Thanks to all for your help.
    Jay
    Attached Thumbnails Attached Thumbnails JT at Patches 086.jpg   JT at Patches 089.jpg   JT at Patches 084.jpg   JT at Patches 085.jpg
    Only time I have seen that milky substance is when oil is mixed with water. I think that year had coolant running thru the manifold unlike the newer "dry manifold" engines. I am not sure though, and someone will probably come along and confirm or deny my thinking. Could have been a manifold leak. How does the oil look on your dipstick?
    The milky oil is concentrated under something that looks like a PCV valve. Still not good as it comes from the drivers side valve cover.
  1. 1996-3500-oil pressure gauge and,fuel gauge spiked
    By vintageenterprises in forum General Chevy & GM Tech Questions
    Last Post: 12-21-2012, 11:02 AM
  2. bad Oil pressure gauge?
    By kdr358 in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 08-21-2010, 11:27 PM
  3. Oil Pressure / Gauge
    By KAHruzer in forum Chevy C/K Truck Forum
    Last Post: 10-07-2009, 12:53 PM
    Last Post: 09-26-2008, 05:10 PM
  5. oil pressure gauge
    By GM_Guy in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 03-01-2007, 03:41 PM
