GM Truck Club
Page 5 of 15 FirstFirst ... 34567 ... Last Post byLast Post by
Results 41 to 50 of 146
  1. #41
    Legend
    TRPLXL2's Avatar
    Jan 2009
    Norwalk, Ohio
    Bought some new 1.7 Scorpion roller rockers, we ordered candy apple red and they sent anodized blue WTF? Oh well, they are not visible anyways but still!
    Ralph took a bunch of pieces off to repaint, It was all sprayed with PPG Bulldog adhesion promoter, and then base coat clear coat finish to match the truck.
    Picture of the glass back in the truck, that window tint looks dark for 35% I think. I don't know I think they might have given us 20% by mistake lol, but it looks cool!
    Click image for larger version.
ID:	48837Click image for larger version.
ID:	48838Click image for larger version.
ID:	48839Click image for larger version.
ID:	48840Click image for larger version.
ID:	48842Click image for larger version.
ID:	48843Click image for larger version.
ID:	48844Click image for larger version.
    - - - Updated - - -
    Started marking wires on the C2 connector, I used a large notebook to keep track of what was getting spliced where.
    The collection of AN fittings we used for the 4l60e lines, 20ft. of AN-6 braided line for the transmission cooler. We bought the transmission cooler from JEGS for $99.99, It has a 2200cfm electric fan hooked to it to cool the fluid faster.
    The AN lines are a real PITA to put together, they sell special tools to make this easier but you'll have a couple hundred dollars just in the tools. Using a hose clamp made easy work for cutting the line with a cutoff tool.
ID:	48861Click image for larger version.
ID:	48862Click image for larger version.
ID:	48863Click image for larger version.
ID:	48864Click image for larger version.
ID:	48865Click image for larger version.
ID:	48866Click image for larger version.
ID:	48867Click image for larger version.
    - - - Updated - - -
    More pics of the transmission cooler mounted, we mounted back under the bed of the truck. We already had too much up front, and didn't want to restrict any more airflow than necessary. Ralph did have a transmission cooler on his truck before, BUT he used rubber lines for the hoses. The line blew while he was at a stop light, and basically purged all the fluid out and the truck had to be towed home. That Is why we did all braided lines this time, didn't want to make the same mistake twice.
    Some test fitting of the newly painted fuse box, this is the brain of the swap.
ID:	48880Click image for larger version.
ID:	48881Click image for larger version.
ID:	48882Click image for larger version.
ID:	48875Click image for larger version.
ID:	48876Click image for larger version.
ID:	48877Click image for larger version.
ID:	48878Click image for larger version.
    2004 Chevy Colorado
    LS1 5.7 swap/TBSS rear axle swap
  2. #42
    Legend
    TRPLXL2's Avatar
    Jan 2009
    Norwalk, Ohio
    Freshly painted battery box, fuse box and other goodies.
    ​Routed the wires down the transmission tunnel, and hooked up the 02 sensors.
ID:	48909Click image for larger version.
ID:	48910Click image for larger version.
ID:	48911Click image for larger version.
ID:	48912Click image for larger version.
ID:	48913Click image for larger version.
ID:	48914Click image for larger version.
ID:	48915Click image for larger version.
  3. #43
    that thing sure is gonna be nasty when its done.
    man i wish i could see it. You HAVE to post a another video of the completed project!
    Alex
    2011 GMC Sierra SLE 5.3 Z71 4X4 Stealth Gray Metallic / 2004 Chevy Impala LS 3.8 Cappuccino
    Tow mirrors - Diablew Tuned - Flowmaster Regular 40 - Ready Lift 2.5' lift - BFG LT A/T K/Os - Carr Light Wing - TruckLite LED lights - Optima Red Top - 50% Front Window Tint - Line-X bedliner - Airaid MIT - Tekonsha P2 - ARS Billet Grill - Fia custom fit seat covers
  4. #44
    Legend
    TRPLXL2's Avatar
    Jan 2009
    Norwalk, Ohio
    I only have a few videos of the truck, I will load them when I can figure out how to format them correctly. I plan on buying a GoPro Camera to make some good videos.
    The engine has had Mobil 1 synthetic since new, so we kept with that trend.
    Some pics of the engine cover all painted and ready to go, this will be getting airbrushed this summer.
    ​The headers were cut and modified, and then rewelded to fit the drivers side. 2 of the primaries were shortened, and heated up and reformed to clear the steering shaft.
ID:	49007Click image for larger version.
ID:	49008Click image for larger version.
ID:	49009Click image for larger version.
ID:	49010Click image for larger version.
ID:	49011Click image for larger version.
ID:	49012Click image for larger version.
ID:	49013Click image for larger version.
    - - - Updated - - -
    You can see where we had to dent into the floor pan, and the PNP connector on the side of the transmission.
    Temporary hot wires ran to the fuse box, and temporary wires ran into the cab for the obd2 port, and gauge cluster.
    The wires draped over the front fender are one's that at the time I didn't know what to do with them, I figured them out later on in the swap.
    Had a hell of a time getting the steering column back together, but we got er' done!!
ID:	49017Click image for larger version.
ID:	49018Click image for larger version.
ID:	49019Click image for larger version.
ID:	49020Click image for larger version.
ID:	49021Click image for larger version.
ID:	49022Click image for larger version.
ID:	49023Click image for larger version.
  5. #45
    Legend
    TRPLXL2's Avatar
    Jan 2009
    Norwalk, Ohio
    Ralph fabbed up some brackets to hold the LS1 fans, Ironically they worked perfect with the Colorado radiator and radiator support.
    Ralph's friend welded up the headers, they came out really nice. The only down fall to it, was he had to grind the powdercoating off where he welded, and now they have turned black in those spots. We are going to have them redone, because you can see them through the fenderwells.
ID:	49051Click image for larger version.
ID:	49052Click image for larger version.
ID:	49053Click image for larger version.
ID:	49054Click image for larger version.
ID:	49055Click image for larger version.
ID:	49056Click image for larger version.
ID:	49057Click image for larger version.
    - - - Updated - - -
    I decided to wrap the headers down under the firewall, because they came very close to the PNP wiring harness.
    When It came to starting the truck, this brought up a new problem. The BCM is the trigger for passlock, and letting the starter engage. After countless hours of researching and reading diagrams, we decided not to mess with the BCM and we bought a push button starter. Very simple to hook up, basically supply a ground, 12v constant, 12v on ignition, and your good to go. It also included a 40 amp relay, we decided to mount it in the traction control mounting plate on the dash. (It has been working flawlessly for over a year now, no problems what so ever.
    To start the truck we just turn the key to "ON", and then hit the starter button and everything functions normally.
ID:	49081Click image for larger version.
ID:	49082Click image for larger version.
ID:	49083Click image for larger version.
ID:	49084Click image for larger version.
ID:	49085Click image for larger version.
ID:	49086Click image for larger version.
ID:	49087Click image for larger version.
  6. #46
    Legend
    TRPLXL2's Avatar
    Jan 2009
    Norwalk, Ohio
    We took the fog lights out from behind the front grille, and relocated them to under the rear bumper as reverse lights. These are 55 watt PIAA extreme white bulbs, they are tapped into the reverse lights with an inline fuse.
    Performance Accessories wanted $187.00 for the fenderwell gaurds, which was ridiculous so we bought a set of guards off of a 97 Silverado for $10 at a swap meet. We trimmed them down to fit, we just used the rear ones.
    The wheels and tires in the pics have been sold, and currently is on jack stands awaiting tax time to buy new rolling stock
ID:	49126Click image for larger version.
ID:	49127Click image for larger version.
ID:	49128Click image for larger version.
ID:	49129Click image for larger version.
ID:	49130Click image for larger version.
ID:	49131Click image for larger version.
ID:	49132Click image for larger version.
    - - - Updated - - -
    ​Putting it all back together
ID:	49139Click image for larger version.
ID:	49140Click image for larger version.
ID:	49141Click image for larger version.
ID:	49142Click image for larger version.
ID:	49143Click image for larger version.
ID:	49144Click image for larger version.
ID:	49145Click image for larger version.
  7. #47
    Legend
    Enkeiavalanche's Avatar
    Apr 2010
    Piermont,NY, back in Northern NJ now, But may be in IL soon....
    look'in Good....
    08 Z71 Avalanche Mods to date: K&N CAI,Hellwig Swaybars and End Links, Corsa Sport Exhaust, Superchips Programer,IPCW LOF & 3rd brake light and tails, AMI Gas door,Show Hooks and Door locks, Enkei Wheels, with Pirelli tires, StreetScene Bowties, Grant Steering wheel,Muth signal mirrors,SSBC Big Brake kit,Huskyliner Mug gards,Floor mats and Hood shield, McGard Lug nuts and locks, Bedrug, Cervini's Ram Air hood,35watt HID Fog lights, Sylvania bulbs all around ZXE's Highs and Lows, WhiteNight Back up lights,Sirius and HD Radio, SnugTop sitting on deck now Got a Softopper on now,Tempress Boat Hatches.... New Bilstein shocks are on... New Mods coming soon..... X
  8. #48
    Legend
    TRPLXL2's Avatar
    Jan 2009
    Norwalk, Ohio
    Power steering pump ($150.00), PS pulley $50.00
    2-6' sections of Goodyear heater hose ($20.00)
    Vacuum Tee $1.97, and PCV valve $0.97
    Pabst Blue ribbon 40 oz. glass bottle, and universal windshield washer pump (priceless)
    2-02 sensors from Rock Auto $30 each
    Pack of 4 Ron Francis marine grade 50 amp relays, $85.00
    ​Spark plug wire heat boots, $30.00
ID:	49190Click image for larger version.
ID:	49191Click image for larger version.
ID:	49192Click image for larger version.
ID:	49193Click image for larger version.
ID:	49194Click image for larger version.
ID:	49195Click image for larger version.
ID:	49196Click image for larger version.
    - - - Updated - - -
    Bought a Spectre intake from Summit Racing for $128.00, It is for an 03-06 Silverado 4.8/5.3/6.0.
    I used an LT1 MAF sensor, as the LS1 and LT1 share the same part # MAF sensor.
    Extended the 02 sensors to reach there new location, always use lead solder on 02 sensor wires.
ID:	49198Click image for larger version.
ID:	49199Click image for larger version.
ID:	49200Click image for larger version.
ID:	49201Click image for larger version.
ID:	49202Click image for larger version.
ID:	49203Click image for larger version.
ID:	49204Click image for larger version.
  9. #49
    Did you use a relay for the back-up lights?
    1996 Chevy Tahoe LT 5.7L V8 4X4 205,000+ miles. Built proudly at Janesville Assembly in Janesville, Wisconsin
    Basic mods: Lights all over, bunch of electrical work, and a couple cooling mods.
    Check out my other mods in My Garage: http://www.gmtruckclub.com/forum/sho...t-Tahoe-4-Door
  10. #50
    Legend
    TRPLXL2's Avatar
    Jan 2009
    Norwalk, Ohio
    No we didn't use a relay for the reverse lights, although they are wired into the factory aux light relay and fuse up front. We haven't had any problems yet, but yes It is good practice to use relays if possible.
    Hooked up the heater hoses, we are eventually going to these in AN lines to make them less of an eye sore.
    Clearance shots of the electric fans, very tight against the air intake.
    We mounted the Ron Francis relays behind the driver side marker light.
ID:	49213Click image for larger version.
ID:	49214Click image for larger version.
ID:	49215Click image for larger version.
ID:	49216Click image for larger version.
ID:	49217Click image for larger version.
ID:	49218Click image for larger version.
ID:	49219Click image for larger version.
Similar Threads
  1. Did a 2006 Silverado front end swap on my truck. Lots of pics!
    By Kyles03 in forum Photo & Video Gallery
    Last: 06-09-2014, 11:10 PM
  2. pics of my motor swap
    By somonenew1994 in forum GM Powertrain
    Last: 02-24-2010, 03:19 PM
  3. Colorado LED Bed Lights,...............PICS
    By seffieldvillage@aol.com in forum Photo & Video Gallery
    Last: 02-12-2010, 06:42 AM
  4. UPDATED pics of the Colorado
    By NORMSCOLORADO in forum Photo & Video Gallery
    Last: 02-09-2009, 10:08 AM
  5. Pics of my new(er) 2005 Colorado Z71
    By SSwt00SS in forum Photo & Video Gallery
    Last: 04-10-2008, 08:40 AM
