Page 9 of 15 FirstFirst ... 7891011 ... Last Post byLast Post by
Results 81 to 90 of 146
  1. #81
    i love this thread, gives me something to show my wife and say, "See, it could be worse...."
    Alex
  2. #82
    Thats an awesome find on the rear end. Oh and I love the diff cover
    David
    1960 Land Rover Series II 88
    2001 Pontiac Sunfire
    NRA Life Member
  3. #83
    Enkei- I have seen that done on an S10, and It was pretty cool! We don't need hydraulic problems though!!
    SierraOwner- Your comment cracked me up!! A lot of guys I know think it's cool that both me and Ralph work on stuff together, but honestly it is the worst thing ever. We spend twice as much!!
    DS Floyd- Pick A Part has 2 more of these still, $500 each. Thanks for the compliment on the cover, I am sure people will notice it at car shows too.
    Here you can see the width difference between the two axles, they were not centered in this picture though. When centered each axle is 2.5" longer, than the Colorado axle.
    We stripped the back of the truck completely down, gas tank, leaf springs, emissions crap, and then we painted everything with gloss black rustoleum.
    We bought some new spring perches, as the Colorado perches were too small to fit the TBSS axle tube. The new perches were perfect, except the centering hole where the alignment pin goes. It was way too big, so we had a friend weld in some material to make the fitment right.
    We removed all ABS components, and switched to mechanical brakes throughout the truck. This involved removing all the factory brake lines, running all new braided stainless lines, AN fittings, propertioning valve, removing ABS and traction control components.
    We also added a line lock, for additional fun. Stay tuned for more updates!!
ID:	50604Click image for larger version.
ID:	50605Click image for larger version.
ID:	50606Click image for larger version.
ID:	50607Click image for larger version.
ID:	50608Click image for larger version.
ID:	50609Click image for larger version.
ID:	50610Click image for larger version.
  4. #84
    Hide that Rear end..... We got Young ones here..... Look'in good..
  5. #85
    For the rear brakes none of the factory setup would work, so we decided to run Russell braided stainless line and AN fittings. Banjo bolts are 10mm-3AN, Russell speed bleeders, one 30" brake line, and one 36" brake line. Two 10mm-3AN fittings for the brake tee, cost all but $75 to do all the rear lines.
ID:	50696Click image for larger version.
ID:	50695Click image for larger version.
ID:	50694Click image for larger version.
ID:	50693Click image for larger version.
ID:	50697Click image for larger version.
ID:	50698Click image for larger version.
ID:	50699Click image for larger version.
  6. #86
    Some pics of the rear end mocked up in the truck, bed sanded down and rubbed down with thinner. Masked everything off, and painted and clear coated the whole underneath of the bed.
    We decided to relocate the gas tank to inside the bed, we bought a toolbox from Tractor Supply Company. It is a perfect fit, We put a piece of foam under the tank, It is properly strapped down and vented out underneath the bed. We did this for 2 reasons, first being for weight distribution over the rear axle. Second is for safety in the event the driveshaft would break loose, It will not hit the gas tank and make a huge disaster.
ID:	50737Click image for larger version.
ID:	50738Click image for larger version.
ID:	50739Click image for larger version.
ID:	50740Click image for larger version.
ID:	50741Click image for larger version.
ID:	50742Click image for larger version.
ID:	50743Click image for larger version.
  7. #87
    Can't wait to see it in Person......
  8. #88
    Master Mechanic SupplySgt's Avatar
    Feb 2010
    Middle TN, displaced Okie
    Very nice! I'm liking the progress!
    93 Suburban (Southern Slayer): TBI 350, 4L60E
    73 Z28 Camaro: L82, TKO 600
    KJ4CLI
    "...Death smiles at us all, all a man can do is smile back..."
  9. #89
    Enkei- We will be at the GM Nationals in Carlisle for sure, and we will also be at the Truck Nationals. You'll see the smoke flying lol!!
    SupplySgt- Thank you very much for the compliments, I try to entertain as best as I can..
    Ralph painted the toolbox/gas tank to match the truck, and we also made a new fuse box cover since the old one got broken during the swap. You can see the shine on the pieces, after Ralph put about 5 coats of clear on them.
    We originally had the calipers painted to match the truck, but the paint did not hold up to the heat so he sandblasted them down and primed them. We bought the VHT caliper paint kit from Summit Racing, very impressed with the quality of paint in the kit. We shall see if they hold up, bought new brake pads for the front (Evolution) and got a set of brand new rotors from another Colorado owner for a case of beer lol!!
    Ralph also replaced the ball joints, which one side was torn and the other side had quite a bit of movement in it. Rockauto $29.00 each, MOOG.
ID:	50764Click image for larger version.
ID:	50765Click image for larger version.
ID:	50766Click image for larger version.
ID:	50767Click image for larger version.
ID:	50768Click image for larger version.
ID:	50769Click image for larger version.
ID:	50770Click image for larger version.
  10. #90
    Look'in Real... Red.....
  1. Did a 2006 Silverado front end swap on my truck. Lots of pics!
    By Kyles03 in forum Photo & Video Gallery
    Last: 06-09-2014, 11:10 PM
  2. pics of my motor swap
    By somonenew1994 in forum GM Powertrain
    Last: 02-24-2010, 03:19 PM
  3. Colorado LED Bed Lights,...............PICS
    By seffieldvillage@aol.com in forum Photo & Video Gallery
    Last: 02-12-2010, 06:42 AM
  4. UPDATED pics of the Colorado
    By NORMSCOLORADO in forum Photo & Video Gallery
    Last: 02-09-2009, 10:08 AM
  5. Pics of my new(er) 2005 Colorado Z71
    By SSwt00SS in forum Photo & Video Gallery
    Last: 04-10-2008, 08:40 AM
