Page 12 of 15 FirstFirst ... 21011121314 ... Last Post byLast Post by
Results 111 to 120 of 146
  1. #111
    Wow sorry to hear that. Hopefully this can be a case of disaster makes the second time better.
  2. #112
    First off I am sorry for what happened.. I know how hard you and your family have worked on it...
    I would like to know what started it.. A relay unless it is Over heated should never do that.. And if everything is Fused with the right Amp fuse that should stop a short when it pops.. Not saying that you did something wrong but it's hard to say now..
    Have you contacted PIAA?
  3. #113
    Dang Sorry to hear that. Hopefully the fire was contained enough that is mostly cosmetic and then obviously the wiring. Keep us posted on how it goes.
    David
    1960 Land Rover Series II 88
    2001 Pontiac Sunfire
    NRA Life Member
  4. #114
    This fire has definately made us think twice about aftermarket lighting, as of right now we still have all the lights on the truck but nothing is hooked up. A week before this happened, our Piaa fog lights quit working so we trouble shot the wiring, relay, and fuses. Turned out the relay went bad, no big deal because these lights are about 5 years old anyways. We ordered one through Piaa for $40.00 shipped, installed the relay and right away it started clicking loudly. We disconnected the battery, and came back the next day to hook the battery up to find out the clicking was gone. Against better judgement we left the relay in, the fire started at the fog lights. It was definately our fault for leaving a faulty relay in, but we will build it back twice as good as before.
ID:	55323Click image for larger version.
ID:	55322Click image for larger version.
ID:	55321Click image for larger version.
ID:	55320Click image for larger version.
  5. #115
    HHHmmm Loud clicking sound Bad ground somewhere.. or something was not hooked up right..
  6. #116
    I agree with you 100% Glenn, but sometimes people just won't listen and they have to learn from they're mistakes. I posted those pics to show everyone what COULD happen, with sloppy wiring practices and I hope this is a lesson learned that won't happen again lol!!
    I took the ECM out of the truck, and decided it needed a little something. I used a dremel and a polishing bit, and went to work for 2 hours with the jeweler's rouge. I then took candy apple red paint, and painted the DELCO letters to match the truck.
ID:	55331Click image for larger version.
ID:	55330Click image for larger version.
    When we assembled the engine we used all Fel-Pro gaskets, including the exhaust manifold gaskets. Well we didn't even get 500 miles out of them, before we suffered massive exhaust leaks on both banks of the motor. We bought some copper MLS header gaskets from Summit Racing, $40.00 a pair and we bought two pairs. It was suggested that doubling the gaskets will help with the excessively thick header flange, and take up and abnormalities on the mating surface of the head. They worked like a charm!!!
ID:	55337Click image for larger version.
ID:	55336Click image for larger version.
ID:	55335Click image for larger version.
ID:	55334Click image for larger version.
    Ralph cut down the shifter, and drilled and tapped it to accept the Pabst beer keg handle.
    Pics of the engine bay getting back to normal, we bought an aftermarket fuse box from Ron Francis wiring. 6 gang 40 amp per slot maximum. $49.99, marine grade box.
ID:	55355Click image for larger version.
ID:	55356Click image for larger version.
ID:	55354Click image for larger version.
ID:	55357Click image for larger version.
    Painted the brake booster with black tractor paint, Ralph made some new lexan covers for the fuse box area. Pressure washed the whole engine bay with mean green, and purple power. Also bought some new battery post covers.
ID:	55359Click image for larger version.
ID:	55360Click image for larger version.
ID:	55361Click image for larger version.
ID:	55362Click image for larger version.
  7. #117
    Look'in Good.. Love the shifter And I don't drink...LOL You can light it up from the back.. I would use a red LED...
  8. #118
    Great looking project. Lots of hard work for sure.
    Steve
    10 Chevy Traverse LT AWD
  9. #119
    Very impressed. This thread has earned over 12k viewers since January.
  10. #120
    Glenn I love the LED shifter idea, that might happen in the future lol!! Thanks for adding yet another mod to the list.
    12,000 hits does not surprise me at all Steve, very few people have done this swap themselves, let alone document it.
    Ralph had bought a spare dash from a fellow Colorado member, and he decided to smooth and paint it to match the truck. We also decided to replace the heater core, since we had the dash out. It took the both of us 3 hours to get the dash completely out, not a fun job at all lol!!
ID:	55775Click image for larger version.
ID:	55776Click image for larger version.
ID:	55777Click image for larger version.
ID:	55778Click image for larger version.
  1. Did a 2006 Silverado front end swap on my truck. Lots of pics!
    By Kyles03 in forum Photo & Video Gallery
    Last: 06-09-2014, 11:10 PM
  2. pics of my motor swap
    By somonenew1994 in forum GM Powertrain
    Last: 02-24-2010, 03:19 PM
  3. Colorado LED Bed Lights,...............PICS
    By seffieldvillage@aol.com in forum Photo & Video Gallery
    Last: 02-12-2010, 06:42 AM
  4. UPDATED pics of the Colorado
    By NORMSCOLORADO in forum Photo & Video Gallery
    Last: 02-09-2009, 10:08 AM
  5. Pics of my new(er) 2005 Colorado Z71
    By SSwt00SS in forum Photo & Video Gallery
    Last: 04-10-2008, 08:40 AM
