Page 13 of 15 FirstFirst ... 31112131415 Last Post byLast Post by
Results 121 to 130 of 146
  1. #121
    Looks like something I had for dinner last night... J/k God I have not done a dash in over 10 years Now I see why.. LOL
    Keep it going... HOPE to see it and meet you at Carlisle Next year.....
  2. #122
    Glad to see things are coming along again. And yep I can see why I only tear part way into the dash when doing things.
    David
    1960 Land Rover Series II 88
    2001 Pontiac Sunfire
    NRA Life Member
  3. #123
    ​Another reason we tore the dash out, was to straighten out the aftermarket wiring. This is the perfect chance to straighten everything out.
ID:	55781Click image for larger version.
ID:	55782Click image for larger version.
ID:	55783Click image for larger version.
ID:	55784Click image for larger version.
    ​More disaster pics, you can finally see the HVAC unit on the passenger side. We had to take all the internal bracing out as well, to be able to pull the HVAC unit out.
ID:	55786Click image for larger version.
ID:	55787Click image for larger version.
ID:	55788Click image for larger version.
ID:	55789Click image for larger version.
    HVAC Pictures
    This was a royal pain to get out, the linkage cables made it not so fun lol!
ID:	55791Click image for larger version.
ID:	55792Click image for larger version.
ID:	55793Click image for larger version.
ID:	55794Click image for larger version.
    ​The squirrel cage was full of leaves, which was making the HVAC blowing very annoying when It was on.
ID:	55797Click image for larger version.
ID:	55796Click image for larger version.
ID:	55798Click image for larger version.
ID:	55799Click image for larger version.
  4. #124
    The squirrel cage was full of leaves, which I cleaned out by hand and then used the air compressor to flush the small bits out. Further examination showed the resister plug was burnt, which is a common GM problem. More money gone lol!!
ID:	55925Click image for larger version.
ID:	55924Click image for larger version.
ID:	55923Click image for larger version.
ID:	55922Click image for larger version.
    The blower resister was also fried, we bought the resister from Summit Racing for $10.99. We bought the complete wiring harness for the resister from the GM dealer for $35.00, It was easier to do the plug and play harness versus solder the thick wires.
    I took apart the HVAC unit, It is two pieces held together with about 30 T15 torx bolts. It took forever to get it apart, but I'm glad I did because there was all kinds of decay inside the AC condenser as well.
ID:	55929Click image for larger version.
ID:	55928Click image for larger version.
ID:	55927Click image for larger version.
ID:	55926Click image for larger version.
  5. #125
    Ouch Do you have a cabin air filter?
  6. #126
    Glenn thank you for bringing up the cabin air filter thing, I checked on it and his truck has 2 of them. I bet they are filthy, because he smokes in the truck and they've never been changed in the 8 years he's had the truck. I will check them out today, thanks for the heads up!!
    ​I have more pictures, I just have to upload them.
ID:	55948Click image for larger version.
ID:	55947Click image for larger version.
ID:	55946Click image for larger version.
  7. #127
    they should be right under the Pass side dash.... With all that stuff in the fan area I hate to see what the filters look like..
  8. #128
    The original dash was thrown away, as It had a lot of holes drilled in it and switches that were no longer needed. The following pictures are a brand new dash that we bought, Ralph spent about 100 hours sanding, priming, painting, clear coating, buffing, and polishing this piece. He used all OEM paint from PPG, and sprayed through a Devilbiss spray gun. The hole in the top of the dash is for some aftermarket gauges, that you will see later on.
ID:	55978Click image for larger version.
ID:	55979Click image for larger version.
ID:	55977Click image for larger version.
ID:	55980Click image for larger version.
ID:	55981Click image for larger version.
ID:	55982Click image for larger version.
  9. #129
    We had the dash out and cleaned up all the wiring mess, It took just under a week to do. The new dash was installed in about an hour and a half, with two people working steady on it. It really brightens up the interior of the truck. Stay tuned for more updates.
ID:	56003Click image for larger version.
ID:	56002Click image for larger version.
ID:	56004Click image for larger version.
ID:	56005Click image for larger version.
ID:	56006Click image for larger version.
ID:	56007Click image for larger version.
ID:	56008Click image for larger version.
  10. #130
  1. Did a 2006 Silverado front end swap on my truck. Lots of pics!
    By Kyles03 in forum Photo & Video Gallery
    Last: 06-09-2014, 11:10 PM
  2. pics of my motor swap
    By somonenew1994 in forum GM Powertrain
    Last: 02-24-2010, 03:19 PM
  3. Colorado LED Bed Lights,...............PICS
    By seffieldvillage@aol.com in forum Photo & Video Gallery
    Last: 02-12-2010, 06:42 AM
  4. UPDATED pics of the Colorado
    By NORMSCOLORADO in forum Photo & Video Gallery
    Last: 02-09-2009, 10:08 AM
  5. Pics of my new(er) 2005 Colorado Z71
    By SSwt00SS in forum Photo & Video Gallery
    Last: 04-10-2008, 08:40 AM
