    Apr 2012
    Schuylkill Co, PA
    Default 2011 2500 HD grease fittings count
    Hi, I have a 2011 HD, I was curious since it no where states how many grease fittings I have. I have the 6.0 liter, crew cab and 6 1/2 box. I counted 9 today, 3 at each wheel, pitman arm, steering box arm and upper control arm.
    I checked the rear and didn't see anything.
    Thanks in advance.
    Dan
    on my 2000 silverado you have 4 for the ball joints. 4 for the tie rods, idle arm 1,pitman arm 1.
    none in rear.
    Newer cars have " non-serviceable parts" that dont need grease (more of that service life crap). It depends on year mostly, if you replace any parts always get one with fittings like moog or napa. If you are concerned there are grease needles that can get between the boots or through them or you could drill and tap the ball and socket parts but i wouldnt worry about it. The OEM tierods on these are scrawny and go early like 75k then go and get some hearty moogs. The inner tierod fitting is on the centerlink itself not on the tierod. Also bushings have come a long way and holdup alot better these days.
    01' 1500 LT Z71 ECSB 5.3L
    you should have 11 i belive. upper ball joints (2), lower ball joints (2), outer tie rod ends (2), inner tierod ends (2), pitman arm (1), idler arm (2, 1 similar to the pitman arm, 1 up near the top where it mounts to the frame) for a total of 11. that second one of the idler arm can be a real peta at times. i am also ASSUMING you have greasable inner tierods. if you dont have them, well then minus 2 fittings.
  1. Grease Fittings
    By davedyno in forum Maintenance & Upkeep
    Last Post: 05-21-2012, 12:14 PM
  2. 1998 Suburban-C1500- How many grease fittings does it have-found 8.
    Last Post: 01-01-2012, 01:51 PM
  3. How many Grease Fittings?
    By 178kchevy in forum Lifted & Offroad Suspension
    Last Post: 03-24-2011, 08:03 PM
  4. Grease points on 2009 Silverado 2500 Dmax Crew Cab 4wd
    By Oscarvan in forum Maintenance & Upkeep
    Last Post: 09-23-2010, 04:46 PM
  5. grease fittings
    By nickgiacalone in forum General Chevy & GM Tech Questions
    Last Post: 04-15-2009, 11:30 PM
