    Default 97 GMC Suburban Not Shifting Into D or 4th On Freeway
    97 GMC C1500 350 Gas
    135000 miles
    New injectors
    New plugs and wires
    All new O2 sensors
    New Catalytic Converter
    Oil and Trans fluid change now due
    Truck has been fairly well maintained with regular fluids, etc.
    Recent smell of trans or pw steering fluid, but no noticeable drops on driveway or loss on dip stick.
    Odor most pronounced after a freeway drive.
    Rpms are way off. Down shifted from D to 3rd today on freeway. No change in RPMs at all.
    Rpms are 2200 at 53 and 2500 at 60, but that is normal for 3rd gear.
    Usually, rpms are 2000 at 70mph dead on.
    It seemed that the odor appeared after the recent replacement of converters and O2 sensors by Pepboys. But, not certain.
    Truck seems to be shifting into gear a touch harder than normal with a noticeable thud.
    What would be your best guess as to the cause of the truck not shifting up to 4th at freeway speeds?
    Where should I begin to look?
    Thanks very much,
    Tracey
    Jr. Engineer
    Aug 2010
    eas' bum fuk, maine
    check engine light on?
    also check your trans fluid for proper fluid and not burned.
    Default followup
    Quote Originally Posted by a.graham52 View Post
    Yes engine light is on. Fluid is at the bottom of normal level.
    I don't know yet what the engine code is, but I will shortly.
    Jr. Engineer
    Aug 2010
    eas' bum fuk, maine
    That cel could be causing the problem (something's going on and it's putting the vehicle in limp home) or you will have trans codes
    TCC solenoid in the transmission. 97 was the first year that GM used a PWM (pulse width modulation) TCC (torque converter control) solenoid. Basically the ecm sends a signal when the appropriate ranges are met, based on rpms, speed, and throttle position.
    Have it scanned first to see what your code is, but that solenoid is about $20.00 and is easy to change. Since you want to do a fluid change it's the perfect time to do it. You have to drop the transmission pan, let all the fluid drain out. The TCC solenoid is right out in the open, just unplug it from the harness and pull it out of the valve body. Reverse the process.
    Maybe someone else has some other ideas, but the TCC will cause it not to go into 4th gear. There is also the possibility that they damaged the wiring harness going to the transmission while doing the exhaust work, burnt, frayed wires maybe shorting as well. Check wiring under the truck around the transmission.
    Default followup
    Thanks for the very extensive reply.
    I will install a new TCC and fluids and see what the code says as well.
    Tracey
    Last: 03-21-2012, 01:26 PM
  2. Tach bounces all over on freeway - 1995 Suburban C1500
    By jonkun227 in forum GM Powertrain
    Last: 09-03-2011, 10:49 PM
  3. Transfer Case Shifting Motor Not Shifting after Installation
    By derickheggie in forum General Chevy & GM Tech Questions
    Last: 01-30-2011, 10:52 PM
  4. 87 suburban shifting issues?
    By socal77k5 in forum GM Powertrain
    Last: 06-12-2010, 06:05 PM
  5. 96 suburban engine died while driving on freeway
    By sameday09 in forum GM Powertrain
    Last: 07-20-2009, 07:02 AM
