    Default Tank range on the Fullsize
    How far can you go before you run out of gas? the fullsize is suposto have a 30 gallon tank.... but i cant make it to 400.
    so i suspect my odometer is bad. it locked up on me not long ago as well.
    or the tank pick up/sending unit is toasted. it does tend to be rather erratic...and when it touches the color- done.
    so to anyone with the fullsize blazer, tahoe, yukon, even the suburban, how far does your tank get you?
    thanks!
    Jr. Engineer Jamm3r's Avatar
    Dec 2012
    Minneapolis area
    It varies among models. My 'burb has the 38 gallon tank (well, actually two tanks, but they're set up so that the driver never needs to know that). So without a trailer I get 13, maybe 14 mpg, and can burn around 35 gallons of fuel before I feel like I absolutely have to stop, so around 450 miles without a trailer.
    my 05 yukon xl has a 31 gallon tank. I can get just over over 600 miles a tank if I drive all freeway. (around 20mpg) I get just under 500 a tank in the city driving. (around 16mpg)
    good god, that's pretty good in an XL.... is it 2wd?
    Quote Originally Posted by K15 Blazer Guy View Post
    No, 4wd. I get between 19-21 mpg on the highway
    LOL
    is that the 400 cubic inch vortec V8 too!?
    man... i need an engine swap. mines all iron lol
    it is the 5.3L vortec V8 I believe that it is a 325
  1. Tank range on the Fullsize
    By K15 Blazer Guy in forum Chevy Blazer Forum (GMC Jimmy)
    Last: 01-18-2013, 05:15 PM
  2. Replies: 0
    Last: 01-08-2013, 11:50 PM
    Last: 01-07-2013, 06:50 AM
  4. RDS 70 gallon fuel tank auxiliary transfer tank
    Last: 10-16-2012, 05:40 PM
  5. New fullsize owner.
    By Gregsyellorado in forum Chevy Silverado Forum (GMC Sierra)
    Last: 05-25-2011, 10:47 PM
