05-10-2013, 05:14 PM #1Newbie
- Join Date
- May 2013
- Posts
- 4
1997 Sierra 5.0 shakes, loss of power
I have a 1997 GMC Sierra 5.0 with 132k miles. It shakes (drastically more when accelerating) and its throwing a p0300 and p0327 codes. has a new fuel pump and filter. any ideas on what could be causing this?
Thanks in advance!
05-11-2013, 05:13 PM #2Jr. Apprentice
- Join Date
- Apr 2013
- Location
- Iowa
- Posts
- 28
Here ya go. PO300 random cylinder misfire.PO327 Knock sensor low voltage code. Check wire gong to sensor or sensor itself. The PCM uses the knock sensor to detect engine ping or detonation and adjust ignition timing to compensate. Never seen one cause violent shaking on acceleration. Maybe dropping a cylinder. Just a thought.
05-11-2013, 05:13 PM #3Newbie
- Join Date
- May 2013
- Posts
- 4
Update! replaced all the spark plugs and most of the shaking is gone. it idles very low (500-900) now and dies unless you give it some gas.
With what you just said, I think the timing is off because of this mishap. Will check the wire right now.
05-11-2013, 05:16 PM #4Jr. Apprentice
- Join Date
- Apr 2013
- Location
- Iowa
- Posts
- 28
Were the plugs pretty fouled up?
05-11-2013, 05:22 PM #5Newbie
- Join Date
- May 2013
- Posts
- 4
Yes, and one had the electrode broken off
05-11-2013, 05:26 PM #6Jr. Apprentice
- Join Date
- Apr 2013
- Location
- Iowa
- Posts
- 28
May not hurt to do a compression check.
05-14-2013, 10:24 PM #7Newbie
- Join Date
- May 2013
- Posts
- 4
Sorry for the delay,
I don't have access to a compression tester. But today I will be replacing the dizzy cap and rotor, ignition wires, and knock sensor.
Replacing all those still didn't fix my problem.
05-17-2013, 03:49 PM #8Newbie
- Join Date
- May 2013
- Posts
- 4
I replaced the knock sensor connector, and now my only problem is the p0300 - random misfire
1995 Sierra-Transmission clunk, power loss, braking issues
By Marauder_Pilot in forum Chevy C/K Truck ForumReplies: 2Last Post: 03-08-2013, 09:23 PM -
big issue .. 350 motor shakes ..and i only have half power .
By quicksilver8817 in forum GM Powertrain TechReplies: 6Last Post: 03-17-2012, 05:42 PM -
loss of power in my 1997 C/K 5.7L at highway speeds
By bosox91379 in forum Chevy C/K Truck ForumReplies: 4Last Post: 02-03-2011, 01:43 PM -
1997 chevy C/K 5.7L loss of power at highway speeds
By bosox91379 in forum General Chevy & GM TechReplies: 1Last Post: 01-29-2011, 06:33 PM -
1997 5.7 vortec loss of power solution
By alhutto in forum GM Powertrain TechReplies: 2Last Post: 09-08-2010, 02:54 PM
Bookmarks
