Results 1 to 9 of 9
    Default 2001 Suburban 4wd issue
    I have an 01 suburban 1500 4x4. The 4 wheel drive is push button. It's not working. I push the 4 hi or 4 low or auto and the lights switch to whatever button I push. Also, I can hear the actuator working. I have no idea what it could be. I heard if your abs light is on it won't engage so I got that problem out of the way and it's still not working. Any ideas? Thanks.
    check the front actuator. Unscrew it from the axle and put it in 4x4. See if the piston moves out.
    I tried that. The piston moves out. Would the 4wd not work if there wasn't any fluid in the transfer case?
    Quote Originally Posted by cbe295 View Post
    It may or may not work. It may work for a short time. If yours is empty that may be why it is stuck in 4x4
    It's full of fluid. It's not engaging into 4x4. It's stuck in 2wd
    Maybe its the switch on the dash?>?
    00 Chevy Tahoe LT, 5.3 4x4
    As soon as I get money I will buy one and put it in. I got told from a guy that works at advance auto that it could be the switch or the transfer case motor.
    So i put a new switch in and the 4wd still isnt working. Me and a buddy jacked the truck up and hit the 4wd button and could still spin the tires so the front end wasnt locking in.
    I had to rebuild the front diff. The washer type thing in there got pushed around and messed eveything up. Thanks for the help though.
  1. 2001 2500hd trans issue
    By quicksilver8817 in forum GM Powertrain
    Last: 10-13-2012, 04:50 PM
  2. 2001 Silverado 1500 with issue
    By Boostedman in forum Chevy Silverado Forum (GMC Sierra)
    Last: 06-24-2011, 04:57 PM
  3. 2001 Silverado with Ride Control Issue (I don't want it)
    By jpking78 in forum Lifted & Offroad Suspension
    Last: 04-02-2010, 06:29 PM
  4. 04 suburban issue
    By VP705 in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 10-12-2008, 10:09 PM
  5. Late 2001 Suburban Electronic Issue! Any Ideas?
    By amos97 in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 01-16-2008, 08:09 PM
