    Default Cleaned throttle body idle issue.
    Cleaned my throttle body on my 2008 silverado 5.3l and idling a little off. Seems to be too high, anyone know should I take to dealer to recalibrate or is there another option? I decided to clean after check engine came on and code p0121 was reading on diagnostics.
    Sounds like a Job for Seafoam...
    what product did you use to clean ? high idle would indicate a air leak/vac leak.
    the 121 means the MAP and the TPS are out of wack. not within the programed operation. usually a leak.
    This is a problem we always had with the computer-controlled throttle bodies on these new trucks when I was doing my work study at my local GM dealer. As the gunk builds up inside the throttle body, the computer slowly adjusts the idle position of the throttle body to account for it and regulate the air flow at idle. The problem is, when you clean the throttle body and the gunk is suddenly gone, the computer thinks that the sudden change is an incorrect reading and doesn't compensate for that. We would always have to use the Tech 2 to reset the throttle body position whenever we cleaned a throttle body. You could try driving it long enough to adjust itself back, or disconnecting the battery for long enough for the computer to drain all of its residual power and reset, but neither of those is guaranteed to reset the throttle body position.
    The only way that I know 100% works is to use the Tech 2 to do a relearn of the throttle body position sensor so that the computer will put the throttle body back at its normal idle position.
    This why I like the pre 98 vehicles, TPS can be reset by holding the gas pedal 3/4 way down and starting the vehicle and letting off the gas and shutting the vehicle off. BAM!! Tps reset lol!!!
    Good luck with your issue!!
  1. Cleaned the throttle body and now i have problems
    By monroefiredog in forum Chevy Trailblazer Forum (GMC Envoy)
    Last Post: 09-25-2012, 04:07 PM
  2. High idle after cleaning throttle body.
    By Dantheman96 in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 01-30-2012, 06:51 AM
  3. Cold Air Intake issue with throttle body spacer
    By Justin092300 in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 01-06-2012, 03:25 PM
  4. Fuel supply line to throttle body issue
    Last Post: 03-04-2011, 09:14 PM
  5. high idle..what else besides throttle body gasket
    By Big6ft6 in forum GM Powertrain
    Last Post: 08-23-2007, 08:58 AM
