Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 41
  1. #21
    when posting for info on your vehicle giving the failure details does help in helping you.
    The vehicle died is to vague.
    when you get this all corrected post back with how the tranny/transfercase is operating.
  2. #22
    Jcat, died is vague. Driving at around 45 mph, the transmission slipped out of gear ( high rev , no power to trans ) then it fell back into gear without any thump. About a mile down the road the same slip came about and stayed out. There was no liquid at first draining out , that happened after about an hour of sitting on the side of the road.
    I will hopefully be giving a fixed update this weekend.
  3. #23
    Quote Originally Posted by pacaguy View Post
    so the transmission had a leak and the fluid dropped to a level that caused you to have the transmission drop out going at 45 mph. since the fluid flows when the engine is running thru the cooler lines for transmission some times you can miss seeing this type of leak. engine off these lines have no fluid in them so when you park it it will not leak out.
  4. #24
    If your gonna put a new tranny in or rebuild the one thats in it monstertrans.com makes sick trannys and rebuild kits and they are awesome to work with.
  5. #25
    Jcat, got the trans in. Drove it approx 10 miles. The speedo started to do the wobble again and it started to go in and out of gear. There was a new speed sensor installed.
    I made it back to my trans guy. He is going to look at wiring next. Any ideas what I should be looking for. He's not real good at the wiring side of this.
  6. #26
    My guess is the guy does not know what he is doing. what did he do the last time just replace the tranny speed sensor ?
    when you get a scrap yard tranny it must be for your year / model to be sure it will electrically work with the PCM/computer
    it appears that you need to get another or rebuild this one if it is the correct transmission for your vehicle. these 4l60 are not ALL the same changes , are made internally .
  7. #27
    the new transmission is for the 2001 engine . he did only replace the sensor...
    could this be strictly an electrical problem?
  8. #28
    Jr. Mechanic Bowtied's Avatar
    May 2009
    2004 Silverado 5.3L
    any word on why there was dexron in there instead of GM tracII fluid?
  9. #29
    Okay, so I've spoken to two Chevy dealerships , they believe that the computer will need to be flashed and this was without physically seeing the vehicle. So next step is it is going to have it towed to the dealership, there's no way I'll attempt to screw up the trans by driving it. I'm in this to deep to give up. Lesson learned.
    As for why there was red liquid in the transfer case, who knows. Like I stated prior, I did not go over this vehicle very well. I am definitely paying for my poor judgement .
  10. #30
    May 2009
    2004 Silverado 5.3L
    Reflash? And your triple sure the trans is from the right year?
  1. 2002 Silverado Re-Gear?
    By donyms in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 06-04-2012, 11:10 PM
  2. 1997 silverado cant get into gear
    By Jscook36 in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 08-20-2011, 04:08 AM
  3. '04 Silverado Gear Indicator
    By OneWheelWonder in forum General Chevy & GM Tech Questions
    Last Post: 01-11-2011, 10:13 PM
  4. re-gear questions for 08 Silverado
    By canislupis69 in forum GM Powertrain
    Last Post: 09-23-2010, 01:51 PM
  5. 04 Silverado gear oil
    By bgbird in forum Maintenance & Upkeep
    Last Post: 09-18-2010, 12:31 PM
