Results 21 to 23 of 23
02-03-2013, 01:07 AM #21Jr. Apprentice
- Join Date
- Jan 2013
- Posts
- 10
It was at a dealer more than once never had p0301-p0308. only ever p0300 random cyclinder misfire, which they told me the computer can not indentify a single cylinder misfire, so it puts it into the random p0300 catch all bucket. Thats when the one dealer told me it was camshaft lope wear. Also both cats are new.
trplxl2 i wasnt using my heads as a ground I was grounding my heads. I also ran a ground to the coil mounting plate thats mounting on valve covers. I give it one more trip to the dealer and then im either going to run it another 40k with a blinking light or drop of my big block race engines in it. lol
02-03-2013, 06:46 AM #22
Has anyone checked the ECM plugs, for corrosion or backed out pins? I have a spare ECM for everyone of my vehicles for this purpose, It takes 5 minutes to swap the ECM and see if the problem replicates.
My comment with the heads is how they set them up from the factory, LS engines do have several sensors grounded to the heads. Good luck with your truck, It will all work out!!2004 Chevy Colorado
02-06-2013, 03:32 PM #23Jr. Apprentice
- Join Date
- Jan 2013
- Posts
- 10
Just got back from dealer service, most misfires coming from 5 and 8 but others have misfires also but majority were 5 and 8. They pressure cleaned injectors 2x, no difference. fuel pressure good, regualtor checked ok, pull plugs in 5 and 8 they looked fine, ignition tested good. told me it has something deaper, maybe injector but they are thinking lifter or valve guides ????? he also said i have exhaust manifold leaks on both sides, can this cause an issue wiht oxyg sensor ??? Im thinking i have 1 of 4 option, 1 drive it like i stole it, 2 trade it off 3, buy reman heads, 4 buy another engine form salvage yard.
Need some insight...reduced engine power and SES light in 4wd Low
By lube70 in forum GM Powertrain TechReplies: 1Last Post: 01-17-2013, 10:40 AM -
Reduced engine power
By Chris_ce in forum GM Powertrain TechReplies: 3Last Post: 12-23-2011, 09:47 AM -
Reduced engine power help
By NHRASST1974 in forum General Chevy & GM TechReplies: 2Last Post: 05-10-2010, 12:41 PM -
By stuntworks in forum GM Powertrain TechReplies: 2Last Post: 01-11-2010, 07:56 AM -
reduced power warning and engine check light
By caseyjones22 in forum GM Powertrain TechReplies: 6Last Post: 07-21-2007, 11:42 PM
Bookmarks
