Results 11 to 13 of 13
    I think the 01' style fuel rail has the fuel regulator built into the rail, It is not sold seperately. As far as the injectors, are they clogged or what?? I found a good how to on cleaning injectors on a BMW forum, I used CRC non chlorinated brake cleaner and soaked and then blew them out with compressed air. I was amazed at how much crap came out of them, I did a set of injectors with 84,000 miles and a set with over 140,000 and I'm still running both sets with no problems. I checked the injector flow before cleaning, and they were around 7.9lbs, after cleaning they were back at 10lbs.
    If you buy new one's they might not come with new o-rings, if not then you should get the injector rebuild kit x8 ($15.00).
    How where you able to open the injector to clean it? or did you spray cleaner into both sides and then blow out each side?
    I put the injectors in a bench vise, and lightly clamped them in place. Then I filled up the bottoms of the injectors with brake cleaner, If you watch them you can actually see where the junk starts breaking loose and air bubbles come to the top. When they stop bubbling, then I flipped them over and took the compressed air and blew them out. I blew them out over a napkin, and you could see like a sandy material coming out of them. I actually have another vehicle this summer I need to do this too.
    I would run techron injector cleaner and 4 Oz of marvel mystery oil in the fuel 2X and then see if the performance/mpg improves.
    many have this mileage with no injector issues.
    after this fuel system cleaning and the fuel filter replaced then if necessary do the injector/clean/replacement.
    Last: 10-29-2012, 10:00 AM
  2. A/C low presusre switch replacement advise.
    By bazar01 in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 09-05-2012, 06:58 PM
  3. Fuel Injectors Help..
    By Walt6488 in forum Chevy Tahoe Forum (GMC Yukon, Cadillac Escalade)
    Last: 03-13-2012, 11:56 PM
  4. fuel injectors for 99- 5.7
    By gangbox1 in forum Performance & Fuel
    Last: 03-09-2011, 12:35 AM
  5. Fuel Injectors
    By Guamrock in forum Performance & Fuel
    Last: 04-11-2010, 08:08 PM
