    Default Fuel Pump Fuse keeps blowing
    It all started one day when I hit a pothole really hard. The fuse blew and fuel pump stopped. I changed the fuse and was good to go until recently when it started blowing again.
    Now, everytime I am under a load, like plowing through snow, the fuse will blow.
    This past weekend, my fuse blew again but this time I can't get it to stop blowing. Everytime I turn the ignition on, I blow the fuse.
    The fuse is located in the slot marked ECMI.
    How do I find out if it is the pump, the relay, or anything else?
    I am assuming there is a short somewhere. I thought maybe I pinched a wire and am arcing out somewhere.
    There is one black wire and two other wires coming off the tank where I am assuming the fuel pump is. The wire tester just barely has a dim light on one of the wires and nothing on the other. The problem is when I turn the ignition on to test the wires, I blow the fuse.
    Any suggestions?
    Thanks.
    Rob in Wisconsin.
    Year and engine would be useful information.
    On my '98, the ECM -1 fuse feeds power to the PCM and parts of the engine management system. The PCm controls the fuel pump. If you are blowing one of the ECM fuses, the short could be in any number of places other than the fuel pump circuit.
    Could be as simple as a loose or bad ground wire, I'd check those first.
    short and sweet
    If its blowin as soon as you turn the switch on..........( a really good thing..Its doin it!)
    Disconnect wiring at your pump. If it quits...BINGO Reconnect the wiring, and blow another one....You got ti for sure! Replace the pump.
  1. 02 Yukon, PCM B Fuse blowing
    By medflypost in forum Chevy Tahoe Forum (GMC Yukon, Cadillac Escalade)
    Last: 06-14-2010, 03:12 PM
  2. blowing fuse
    By bowershed in forum General Chevy & GM Tech Questions
    Last: 03-30-2010, 07:13 AM
  3. CTSY Fuse Keeps Blowing
    By danman5000 in forum GM Electrical Tech
    Last: 02-18-2010, 04:45 PM
  4. 1997 K2500 keeps blowing 25amp 4wd fuse
    By Appliancepresident in forum General Chevy & GM Tech Questions
    Last: 03-28-2009, 11:32 AM
