    Default need help with 4wd problem on 96 tahoe 4door
    hi i have a 1996 chevy tahoe 4dr 4x4 with the 5.7l push button 4x4 dual vforce exhaust and an aftermarket stereo proffessionally wired, and i put a different set of rims and tires on it (in my heated garage, im from canada) and out of no where the next day i tried to put it into 4wd cause my drive way is icy...and it you could hear a click from the t-case and the 4hi light just flashed and i was like ok so i tried it and i had no power to the front wheels..i kept spinning out in only rwd... so i backed up put the truck in park shut it off turned the power on and tried to put it in 4hi that way and again the t-case made a noise but the 4hi light kept flashing..... i tried it again in neutral and again the t-case made an noise from engaging but the light kept flashing...does anyone know what my problem is...i need it solved asap....as i have a 7 week old son...is it my actuator for my front diff??? i check both fuse boxes and there was a t-case fuse and a 4wd fuse neither of them are blown...
    It could also just be the switch itself as that was the case with my suburban
    Hypertech III, K&N, true dual
    285/75/16
    ___________________________
    Jason
    i found out its due to my abs wire being broken....on my passenger side front wheel well but now i have a diferent issue... it locked up randomly on me and the emergency brake light came on and the brake peddle sank to the floor and i pulled into my driveway and than its leaking a bit of brake fluid out of my rear drivers side brake drum i check the other three and there not leaking!!!
  1. 03-07 Silverado 4Door Master Window Lock Switch OEM
    Last Post: 11-28-2012, 08:00 PM
  2. Replies: 0
    Last Post: 03-05-2012, 07:50 PM
    Last Post: 03-03-2012, 07:00 PM
  4. 96 Chevy tahoe problem fuel problem? Need help ASAP!
    By Fear58 in forum General Chevy & GM Tech Questions
    Last Post: 12-13-2009, 05:38 PM
  5. Replies: 0
    Last Post: 08-17-2009, 04:30 AM
