    Sr. Engineer FergusonT's Avatar
    May 2010
    Southwest Michigan
    Default '99 Silverado Random No Start
    So recently I just did a bunch of fuel system work on this 5.3 Silverado. Pressure regulator, fuel pump, fuel filter, map sensor. And it ran fine for a while but then it randomly just does not want to start. Usually after it has been sitting for at least a few hours.
    One day my wife called, said it wouldn't start at the grocery store. I borrow a car and half way there she calls and says that it started.
    It turns over fine and with starting fluid it will run long enough to burn the fluid.
    One thing I haven't done yet is correctly solder the wires to the fuel pump. I just used the crimp connectors that came with the new harness. So that would be one guess. I did wrap it very well with heavy duty electrical tape though. I have a hole cut for access to the pump so I can get back in later to make the correct connections.
    Also I have been getting codes the 2 obd codes that would indicate a vacuum leak. But usually the ses light only stays on for a few minutes before going away.
    Any thoughts?
    1999 Chevrolet Suburban LS K1500
    1991 Chevrolet S10 4.3L 4x4
    2005 Suzuki Forenza (GM/Daewoo)
    Definately a fuel prob, when it wont start find the test port on the rail and push the valve with a pen or something to see if there is any pressure. Prob the pump connections.
    01' 1500 LT Z71 ECSB 5.3L
    May 2010
    Southwest Michigan
    I just made this interesting. As I was waiting for my ride I figured I would reseat the map sensor. It broke off into the manifold.
    so who is gonna tell me about pulling the intake manifold. sounds like its just time consuming
    The intake isnt too bad to do, hour job if you got the tools all set out. If you unbolt the throttle body you dont have to open the cooling system. Was yours the type on the back or the top?
  1. Headlights and random
    By Nickw059 in forum Chevy Truck Accessories
    Last: 03-16-2010, 01:50 PM
  2. Random won't start issue.
    By grtn316 in forum GM Powertrain
    Last: 12-20-2009, 08:00 PM
  3. Random misfire 97 silverado
    By 97silvy in forum GM Powertrain
    Last: 09-21-2009, 10:17 PM
  4. random
    By npverhey1 in forum General Chevy & GM Tech Questions
    Last: 12-17-2008, 10:46 AM
  5. Random Question
    By MWright936 in forum The Coffee Shop ~ Chit Chat
    Last: 07-16-2008, 01:51 PM
