Results 11 to 20 of 28
    Also, I did spill coolant, I removed the hose from the drivers side of the throttle body.[/QUOTE]
    You could have left it on but like i said but no matter. If you have a 3/8 or 1/4 torque wrench use it because if you dont tighten the intake right it will warp.
    01' 1500 LT Z71 ECSB 5.3L
    Sr. Engineer FergusonT's Avatar
    May 2010
    Southwest Michigan
    Alright got the manifold off, peaked into the port for cylinder 8....and there sits the little rubber piece from my MAP sensor, sitting on top of the closed valve.
    1999 Chevrolet Suburban LS K1500
    1991 Chevrolet S10 4.3L 4x4
    2005 Suzuki Forenza (GM/Daewoo)
    so maybe now with a good MAP the engine will run good. I suspected that your MAF was messed up.
    May 2010
    Southwest Michigan
    You could have left it on but like i said but no matter. If you have a 3/8 or 1/4 torque wrench use it because if you dont tighten the intake right it will warp.[/QUOTE]
    Yeah I saw your post after I had already done it...oh well
    With the codes I was getting, I am wondering if maybe it needed new intake gaskets anyways. Maybe I should replace the MAF as well.
    May 2010
    Southwest Michigan
    Well well....Last night....snapped a manifold bolt..........
    Jr. Engineer
    Aug 2010
    eas' bum fuk, maine
    removing or installign the bolt? time to invest in some broken bolt removal tools.
    May 2010
    Southwest Michigan
    re installing, I got it out though. It snapped up high thank god. Just spent all day running around and calling places, can't find anywhere. Wandered around a junk yard for about 45 minutes, no gm 5.3 motors. Guess I gotta go through the stealership on this one.
  8. #18
    you better get a torque wrench and the torque specs. no reason to break these bolts easy on this hardware. also you must follow the proper torque proceedure . this is why bolts break and components get distorted. all these parts are soft ALUM>>>>.
  9. #19
    The dealership charges $1.35 for the bolt, and have them print off your torque specs. Take your vin # with you, so they give you the correct one's for your vehicle. The only thing I will say about it is the torque sequence is done in 3 passes on each bolt, staggered in a pattern like a star. Make sure you read it real close, because they go from inches-lbs, to ft-lbs. and it's easy to screw up!
  10. #20
    May 2010
    Southwest Michigan
    I've got the specs and the sequence from a haynes manual, the problem was I was using a bad torque wrench. I was using my dads old wrench, he goes "oooh yeah, I used that on my '67 Camaro back in the '70s." It had to have been off, it was saying 40lbs and it snapped a bolt.
  1. muffler fell off!
    By reggiecab2000 in forum Chevy Truck Talk & GM News
    Last: 09-05-2012, 10:02 AM
  2. Wheel fell off while driving.....
    By Josh in forum Lifted & Offroad Suspension
    Last: 02-08-2012, 07:25 PM
  3. Sensor on intake manifold
    Last: 10-12-2009, 11:41 PM
  4. I fell into a candy stupor!
    Last: 11-10-2008, 01:19 PM
  5. The front fell off!
    By ChevyFan in forum Photo & Video Gallery
    Last: 08-08-2007, 11:52 AM
