Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
  1. #21
    What the hell were u torquing to 40lbs? Hope u ment in-lbs and not ft-lbs
  2. #22
    You prob ruined the gaskets and warped the intake with 40lbs. Was it 1/2" drive?
    01' 1500 LT Z71 ECSB 5.3L
  3. #23
    X2- That is waay to much, If I remember right it's around 12lbs of torque.
    The Hayne's manual is probably out of date, they come out with torque revisions all the time. If we would have followed the Haynes manual when doing our engine rebuild, 90% would have been incorrect.
  4. #24
    Sr. Engineer FergusonT's Avatar
    May 2010
    Southwest Michigan
    Haynes was right, I just didnt realize it was Inch/lbs. I was right around 40lbs....it did crush one of the rubber grommets on one of the bolts, as well as broke another.
    Just being in a hurry not paying attention to detail, in the freezing cold.
    Gaskets look alright, intake looks alright.
    According to this conversion calculator thing, It should be around 8lbs. Damn. ...I ordered a new set from the dealer today.
    Thats the final torque spec. I believe it has 2 steps, 1 is 44 and 2 is 89 inch/lbs
    1999 Chevrolet Suburban LS K1500
    1991 Chevrolet S10 4.3L 4x4
    2005 Suzuki Forenza (GM/Daewoo)
  5. #25
    My gasket surface OCD is screaming looking at that picture but since I live in n. ohio and its about 19* highs I won't break your balls. Those are fel-pros just warranty them out, they dont care if you fudged it and even if they did they wouldnt know.
  6. #26
    May 2010
    Southwest Michigan
    Warranty the gaskets out? I pulled them off and see nothing wrong with them.
    Unless I am missing something, which is likely given my track record on this project...I got a good look at the new gaskets before I put them on. After this mishap I pulled everything back off immediately and they looked no different.
  7. #27
    why risk an intake leak just because you didnt "see" a problem with them. take the taime and get new gaskets.
  8. #28
    May 2010
    Southwest Michigan
    So looking at the bolts and the way the manifold gaskets have rubber that goes around the bolt holes, I am assuming that the bolts and the sleeves on the bolts are designed to seal the manifold when tightened. I just had to order a whole new set of bolts because most of the rubber seals on them were slightly torn.
    Also, what can I use to clean the injectors with while I have everything out.
  1. muffler fell off!
    By reggiecab2000 in forum Chevy Truck Talk & News
    Last Post: 09-05-2012, 10:02 AM
  2. Wheel fell off while driving.....
    By Josh in forum Lifted & Offroad Suspension
    Last Post: 02-08-2012, 07:25 PM
  3. Sensor on intake manifold
    Last Post: 10-12-2009, 11:41 PM
  4. I fell into a candy stupor!
    Last Post: 11-10-2008, 01:19 PM
  5. The front fell off!
    By Steve in forum Photo & Video Gallery
    Last Post: 08-08-2007, 11:52 AM
