    Default AC Pump??Can it be used for?
    Im throwing around some Ideas but Im not very knowledgable with the AC compressor. Could It be used to fill an airtank for the purpose of running a train horn or fill up tires or anything of the likes without messing up the AC in general?
    4.8L Vortec | 6inch Lift | 35'' BFG ALL TERRAINS | K&N Intake | AirRaid Throttle Body Space | 3inch straight pipe dumped at rear axle | BlackBear Tuned | 2 13in JL Audio Subs | 1000watt HD amp, 2.9 cap | Kenwood Dble Din | Gibson Hi Flo Cats | HIDs Hi/Los 55watt 8000k |4.56 gears |
    No, it can not be used for anything else. It is a sealed unit that moves and compresses freon . It does not actually compress air.
    Thanks, thats what I thought. I was just kinda look for a quick confirmation.
    But if you find one of the old GM pancake compressors it can be used as a compressor, and its mounts and removable pulley allow it to be modified for use on a newer truck.
  1. HELP!!!!Changed fuel pump and ECM. fuel pump still wont turn on
    By fast_stang_88 in forum GM Powertrain
    Last Post: 06-03-2011, 04:46 AM
  2. Where do you pump gas?
    By Silverado1500 in forum Performance & Fuel
    Last Post: 03-28-2011, 03:02 PM
  3. Windshield Washer Pump not working (not the pump)
    By vdubn in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 11-20-2010, 09:39 PM
  4. Replies: 4
    Last Post: 09-19-2010, 06:16 PM
  5. Gas pump fun?
    By Cableguy in forum Performance & Fuel
    Last Post: 05-25-2007, 05:18 PM
