Results 11 to 12 of 12
02-05-2013, 04:01 PM #11
If you are only getting seven volts at the starter battery connection then you have a very bad connection or your battery is shot. It may very well work the lights but not provide the amps needed for cranking or pulling in the solenoid.
2000 GMC YUKON SLT, 5.3L tow pkg, G80 rear/w 3.73 gear
02-06-2013, 11:33 AM #12
Alright, so I figured out the problem. It was the PCM b fuse (20a). This fuse was not in the wiring diagram so that is why I couldn't find it, Plus when i checked all the fuse's i happen to over look it, because it was sorta hidin. But now my question is. When its turning over and right before the engine can run its self, that same fuse blows.
- - - Updated - - -
guess its the fuel pump or a ground in the circuit.2002 Gmc sierra
5.3 v8 1500
k&n air intake
20inch liquidmetal dyno 6's
xlerator dual exhaust.
Similar Threads
Wont crank when hot? could I have the wrong starter?
By Kagami-Suburban in forum General Chevy & GM TechReplies: 2Last Post: 01-30-2012, 11:19 AM -
Power to everything but starter won't turn
By ChameleonBob in forum General Chevy & GM TechReplies: 9Last Post: 06-21-2010, 09:50 AM -
04 Sub Starter Keeps on Going wont shut off
By andylester in forum Chevy Suburban Forum (GMC Yukon XL)Replies: 2Last Post: 01-27-2009, 08:21 AM -
2006 silverado ignition wont switch wont turn
By cgcomeaux123 in forum Chevy Silverado Forum (GMC Sierra)Replies: 5Last Post: 12-01-2008, 04:05 AM -
Engine wont start ??STARTER??
By paradice01 in forum GM Powertrain TechReplies: 3Last Post: 07-09-2007, 02:20 PM
Bookmarks
