    Default 2003 Sivlerado 1500 z71 need help on spark plug wires
    I need to change spark plugs in my truck but not sure how to remove the spark plug wire that has metal sleeve on it i dont want to rip them off and ruin the wires i have tried to removing them but not sure if there is a special way of getting them off could use some adive or help thanks
    Hi, i just did it on my '01 5.3. Some of them I could just grip and pull. If you use a pair of slip joint pliers with good teeth, you can grip the heavy rubber part very hard and pull out at the angle of the plug...they really will come out easily, and you won't hurt the rubber. The metal sleeve slides off and on with no problem after that. Also, you will need a wiggle socket adapter for the rear plug on passenger side.
    Don't be afraid to grip them hard and pull. I also replaced the wires, which turned out not to need replacing, as they had apparently been recently replaced. If you happen to damage one of yours, I can help you out with a replacement.
    Jim
    I just grab the rubber boot and twist back and forth until it breaks loose. Then I pull them off. You could buy the tools the grabs them from the front and pulls.
  1. Replies: 9
    Last: 02-07-2012, 08:32 PM
  2. How To: Test Spark Plug Wires
    By dualdj1 in forum How-to Guides
    Last: 03-15-2011, 09:15 AM
  3. Problem getting the spark plug wires out from the engine
    By Lance Hall in forum General Chevy & GM Tech Questions
    Last: 02-01-2011, 06:16 PM
  4. Spark Plug Wires
    By Crawdaddy in forum GM Powertrain
    Last: 07-25-2008, 12:11 PM
  5. spark plug wires sequence
    By Chevy1997 in forum GM Powertrain
    Last: 08-06-2007, 03:36 PM
