Results 1 to 10 of 12
    Default Question about determining Axle Ratio
    Hi,
    I'm looking into the towing specs on my truck per the users manual. With my truck type, there are two options listed under axle ratio (3.73, 4.10). Can anyone tell me how to find out what the axle ratio on my truck is?
    Thanks,
    Theresa
    what kind of truck is it? someone will help you here for sure dont worry...
    PETE
    95 GMC Sierra 2500
    3" Body Lift, 33" Goodyear MTR's
    5.7L 350 TBI Edelbrock SDT Exhaust, Flowtech Headers, K&N Intake
    Sold :(
    1999 Jeep Cherokee, 3" Rustys lift, 33" BFG MT's, locked, armored: Rolled :(
    2000 Jeep Grand Cherokee Limited. K&N Intake, Custom Kolak Exhaust
    Contact this GMTC Moderator for any problems or questions you may have :great:
    Join the GMTC Facebook Group!!! Join Here
    Thanks. It is a 2003 Silverado 1500HD v8 6.0l crew cab with 4 x 4.
    Theresa
    in the glovebox you will see a sticker with a series of number/letter combinations. These are RPO codes and you can look up online what they stand for then match that to the ones in your glovebox.
    Dan
    1999 GMC Sierra 2500 350 vortec
    1967 Jeep M725 ambulance 230 tornado
    1990 Cherokee Limited- 3 inch lift on 33's
    ...and every one of em has issues
    If you have any questions or problems don't hesitate to send me or any other GMTC moderators a PM
    Correct, if you're certain the gears are the same as installed at the factory, you can use the RPO codes to determine what was installed at the factory.
    Alternatively, you can jack up the rear end, rotate the tires through one revolution if you pick both tires up, or through two revolutions if you only lift one tire, and count the number of times the driveshaft rotates.
    I really do need to post that RPO list I have on here, it is 180 pages long though.
    Here is a link to a RPO decoder on the web courtesy of our friends with corvettes.
    http://s-series.org/rpo/
    And one Big Pain in the Ass When it Doesn’t.
    See a Pattern yet?
    Go to the dealership,give him your VIN number,he can then give you the info. you are looking for.
    Moderator
    dwill3015's Avatar
    Jan 2007
    Yacolt, Washington
    I wonder if we have any GM techs here that can do VIN decoding. Here is a link to a VIN decode I had done on my Silverado on a diesel truck site. It is very detailed.
    Darcy
    Washington State
    Jr. Apprentice WhosDatGuy's Avatar
    Kamloops, BC, Canada
    My rear end is not factory, the elderly gent that I bought the truck off forgot the ratio, how can I find out what gears I'm running.
    Cheers
    Quote Originally Posted by WhosDatGuy View Post
    Cheers
    Method 1 (If you need to change the diff fluid anyway): Open differential. Count the # of teeth on the ring gear and the # of teeth on the pinion gear. RG/PG=gear ratio
    Method 2: Jack up both rear wheels. Put transmission/transfer case in N. Rotate rear wheels through one revolution while counting the # of times the driveshaft rotates. DS rotations/tire rotations=gear ratio. Often times, I prefer to jack up only one rear wheel and count the DS rotations through 2 rotations of that one tire. 2*DSrotations/tirerotation=gear ratio. I often prefer this because, with an open diff (or anything that behaves like an open diff like the stock G80) there might be some question with both wheels in the air if both wheels rotated exactly together.
  1. Axle question
    By OldskoolGP in forum GM Powertrain
    Last Post: 01-09-2010, 08:45 PM
  2. Z71 axle ratio
    By tommyboy in forum Lifted & Offroad Suspension
    Last Post: 04-24-2009, 10:00 PM
  3. question about gear ratio
    By scgamer_99 in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 03-08-2009, 02:10 PM
  4. 08 Silverado 2500 rear axle gear ratio
    By Trident in forum Performance & Fuel
    Last Post: 02-26-2008, 10:08 AM
  5. Rear Axle Ratio, Where Do you Find?
    By Dj Friction in forum GM Powertrain
    Last Post: 08-29-2007, 03:12 PM
