Results 1 to 9 of 9
    Default 2009 Sierra door lock problem
    My 2009 1500 Sierra SLE 4WD driver side door lock does not work. The electric lock control will not work either door, nor does the key fob lock/unlock driver door. So I have to manually push down door lock and use key to unlock/open driver door. Passenger side works fine. Someone mentioned door actuator, can't seem to locate this part online for sale. Any suggestions?
    Alan - Memphis, TN
    2009 GMC Sierra 1500 SLE Ext. Cab 4WD
    Did you check fuses?
    IP fuse panel, fuse #26
    Thanks for the suggestion, but the fuse was not the problem.
    Probably built into the door latch, i have an 01 so i couldnt tell you. After googling some it looks to be part if the latch but you could take the door panel off and look.
    01' 1500 LT Z71 ECSB 5.3L
    It sounds like a power problem, you said you checked the fuse, so maybe it's the wire providing power to the control module inside the door.
    Sometimes, the wires will break in the wire bundle going to the door. There is a lot of flex from the door opening, or closing.
    If nothing on the door works (windows, mirror, etc), it could be a broken ground wire.
    Everything else on the door works, windows & mirrors. When I push the lock/unlock button it makes a buzzing noise, like it wants to work. The door lock moves @ 1/8". When using the passenger lock button it also moves slightly.
    Quote Originally Posted by Double A View Post
    if the passenger door locks / unlocks ok with the switch control but the driver door does not work then it is the wiring going to the actuator or the actuator. open the driver door panel and with meter measure the volts across the actuator when hiting the switch see if there is power going to the driverdoor actuator if the power is there when you hit switch and no action then you got a defective actuator.
  1. Rear door lock problem on 2004 Sierra 2500HD crewcab...HELP!
    By RandyAB in forum Chevy Silverado Forum (GMC Sierra)
    Last: 07-17-2011, 04:37 PM
  2. Door Lock problem
    By TELORVEHC in forum GM Electrical Tech
    Last: 10-26-2010, 03:51 PM
  3. Door Lock Problem
    By 4xbill in forum Chevy Silverado Forum (GMC Sierra)
    Last: 08-07-2010, 11:43 AM
  4. Door Lock Actuator Problem in 01 Burb
    By palmergg in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 08-06-2010, 12:01 PM
  5. Door lock problem on 00' K2500 (old style)
    By Thad in forum Audio, Video & Gadget Tech
    Last: 11-18-2009, 10:08 PM
