Results 1 to 10 of 13
    Default Need help wiring 4 fog/driving lights to front of truck
    Hey guys, I am new to the forum and need some help with wiring fog/driving lights to the front of my truck. I work at an auto parts warehouse and the owner gave me these 4 fog lights... They are originally meant for Mercedes vehicles and they are made by Bosch. I want to mount all four of them in the grill area and will aim them down towards the road as driving lights. Here are my questions: 1) Obviously I cannot use the OEM Mercedes plug, can I cut off the plug and just splice the wires into other wiring to hardwire them into my truck? 2) Should I wire them as two separate sets and then eventually run them into one positive and one ground and then to a switch? 3) I don't know much about electrical wiring, do I need some sort of relay or fuses? what type? Links? 4) I want to wire all four to one switch, is that possible? 5) What power sources do I tap into for power for the lights, as well as the switch? Anything else that I'm forgetting? Here are some pictures of the lights. Also, I have a 2007 1500 New Body Style. The last picture gives you a VERY rough idea of where I want to mount the lights on my grill.. I can run the studs through the gril and use a washer and nut on the back side of the grill to hold them.Click image for larger version.
ID:	49185Click image for larger version.
ID:	49186Click image for larger version.
ID:	49187Click image for larger version.
ID:	49188Click image for larger version.
    I would have a relay supply power to the fog lights from the battery or ignition source . If you want control of these lights then have a interior mounted switch to the relay control coil. if you do not need this then connect the relay coil to the headlights or park light feed.
    the wires will require fuses at each point where you tap off the power.
    I have seen many times the use of just switches supplying power to the lamps and the switches cannot handle the current flow.
    I am assuming that the orange/brownish colored wire is going to be my positive correct? And black is what I'll ground?
    Quote Originally Posted by thellama5652 View Post
    That is true for American made, but it may not be true of European cars. I would pull the cover of one of them to check it.
    black is the ground with these German vehicles. the orange / brown would indicate a fused wire. solid red unfused wire.
    Those look like standard wheatherpack connectors, summit sells a kit that could prob connect to those. I could check if you post some more detailed pics of the connectors. I would wire them as 2 sets as having all 4 on plus the rest of the truck electrics ( hvac, headlights, radio, etc) would be rough on the alternator. You will need fuse holders and relays aswell as a pair of interior switches.
    01' 1500 LT Z71 ECSB 5.3L
    Yeah that would be great - Thanks man. Here are a few more pictures of the connector, a picture of each face of the connector and then the end of it. Click image for larger version.
ID:	49338Click image for larger version.
ID:	49339Click image for larger version.
    One Bosch 30 amp relay should be able to control power to all four lamps. I would first find out what the current requirements are for the lamps so you can figure out what size fuse to use. If you fuse each light then if one messes up you only lose one from the fuse blowing.
    And other vehicles and toys.
    Yeah, that makes sense. I was trying to figure out the power of the lights but there is no wattage printed on the lens.. Any other ideas how to find out?
    if you have a voltmeter with amps measuring they should have a 10 amp selection. place the meter in series with the light feed. positive to positive not across the light input.with this amount I would guess 5 amps then 5X4 =20amps. so using a 30 amp rated relay would be correct. need at least 20% safety factor for reliability.
  1. 03 04 chevy silverado truck fog lights oem type+ wiring
    Last: 05-23-2011, 01:00 AM
  2. 03 04 chevy silverado truck fog lights oem type+ wiring
    Last: 03-12-2011, 11:40 AM
  3. 03 04 chevy silverado truck fog lights oem type+ wiring
    Last: 01-02-2011, 08:20 PM
  4. 2003 2004 chevy silverado truck fog lights oem + wiring
    Last: 08-22-2010, 07:00 PM
  5. Wiring driving lights
    By Als09Sierra in forum GM Electrical Tech
    Last: 03-28-2010, 07:12 PM
