Page 2 of 4 FirstFirst 1234 Last Post byLast Post by
Results 11 to 20 of 38
Thread: Light Bar Idea
    Well @SurrealOne told me about using a voltage regulator. I made a full diagram for the integrated circuit I will need to build to make these lights work. Hover over the image to see better. It will use three SPDT relays to switch between running lights at 5v and brake/turn functions at 12-14.4v Normal function will be running lights then it will switch to functions.
    I've done some pricing on the IC and its gonna cost about $70-80 including prototyping it. The parts are cheap just its a lot of them. This wont be built until around March. Each LED strip costs about $3-4. Already got one for close to free just need 4 more. And even after all this and building a front light bar mount I will save over 100 dollars. Can't beat that!
    Did some testing of my light's draw at certain voltages. The white LED strip draws 250mA at 12-14v; At 5v it draws only about 13mA. I hope this holds true for the red ones as well. I need to keep every thing under 1 amp. The 3 red strips will draw only about 40mA at 5v together at 12v they will draw about 750mA together, but at 12v they are all powered by a separate supply so each will draw 250mA from their relay.
    Pics of the red LED strip most are at full brightness. Remember there will be three of these illuminating my trucks rear end while braking. Should make my truck super visible to others. I may post more pic of both strips.
ID:	49850Click image for larger version.
ID:	49851Click image for larger version.
ID:	49852Click image for larger version.
ID:	49853Click image for larger version.
ID:	49854Click image for larger version.
ID:	49855Click image for larger version.
ID:	49856Click image for larger version.
ID:	49857Click image for larger version.
ID:	49858Click image for larger version.
ID:	49859Click image for larger version.
ID:	49860Click image for larger version.
    More pics in the pitch black.
ID:	49888Click image for larger version.
ID:	49889Click image for larger version.
ID:	49890Click image for larger version.
ID:	49891Click image for larger version.
ID:	49893Click image for larger version.
    I think all pics after this point are the lights at 5v. Above they are at 12v
ID:	49892Click image for larger version.
ID:	49894Click image for larger version.
ID:	49896Click image for larger version.
ID:	49897Click image for larger version.
    If this does not work out you can always mount them under the Tahoe model you have... Sorry.. Nice pics..
    Or as accent lights in the truck. I need to order more strips now. One more white and 2 red.
    I have 8 of those red strips inside my truck, everybody calls it a whore house on wheels lol!!! It does have that look to it though, I give you a lot of credit for this project. I would just buy the premade bar and call it a day, but you learn a lot more the way your doing it...
    I don't know which is cooler ... a whore house on wheels or that you think it be labeled as such is funny.
  8. #18
    At first I saw only Surreals post from my profile and I was thinking what in gods name brought that up. @TRPLXL2 I can't use a premade bar because they don't fit my truck. I looked it up long before planning this project. The Tahoe's with tailgates can't fit the bar while the gate is down because of how the top bumper trim is made. Any way my bar will fit my style better and allow me to fix any problems with it.
    Also I don't intend to use the red for the inside of the truck more likely if this doesn't work the red strips will be mounted under my hood to give the engine a cool red glow while open.
    Did price annalysis and the total cost of light bar including buying things like a bread board, jumpers, and bulk wire. Ends up to be a little over 100 dollars.
  9. #19
    You for got to add Labor....
  10. #20
    @Enkeiavalanche,
    I don't want to think about how much I owe myself in labor. You shouldn't encourage a young modder to think about that, either, unless you want him to quit modding.
  1. What do you think about this idea? good idea or dangerous?
    By tnelson73 in forum Chevy Silverado Forum (GMC Sierra)
    Last: 01-02-2012, 05:23 PM
  2. Is this a good idea to save gas at the pump? (Increase MPG Idea)
    By ShadowRejects in forum Chevy C/K Truck Forum
    Last: 10-22-2011, 01:38 AM
  3. Just an idea has anyone done this?
    By aficio400 in forum The Coffee Shop ~ Chit Chat
    Last: 11-25-2010, 09:56 AM
  4. I have no idea what to do now???
    By vncj96 in forum General Chevy & GM Tech Questions
    Last: 01-05-2010, 03:19 PM
  5. New Mod Idea
    By CornhuskerChevy in forum Performance & Fuel
    Last: 10-04-2009, 01:53 PM
