Thread: Cold Engine
    Default Cold Engine
    I have a 2013 Suburban with the small V8 engine. Normal engine temp puts the gage right about on the 210 mark if I can get it there. In cold weather I cant even get to the 210 mark unless I get on the interstate and run it up to 65 mph. Then it will warm up. The other day I went up a hill to pick up a bag of ear corn and it did warm up to 210 going up the hill but coming back the gage dropped back to the half way mark and never got back to 210. The dealer put a new thermostat in it about a week ago but it still keeps doing this. In real cold weather it never gets past the half way mark no matter how far you drive. What else could cause this problem since the thermostat has already been replaced?
    Those are perfectly normal temps. The thermostat is set at 195 usually My truck never reaches 210 unless it is a very hot summer day. Your Burb has electric fans that cool better than my mechanical fan so of course your temps will stay lower.
    The electric fans could possibly be coming on and cooling things down, you can check to see if their running before the engine temp reaches I believe 180 range.
    Depending on how cold the weather is where your at it may just be that your engine is cooled to well and you could need to mask all or part of the radiator to get the temps up a little. Kind of like Semi's do in the winter time to keep their diesels running at optimal temperatures.
  1. engine ran cold, then overheated?
    By Olsy in forum Chevy C/K Truck Forum
    Last Post: 11-20-2010, 01:49 PM
  2. 96 K1500 hard starting when engine cold
    By kcstrom in forum General Chevy & GM Tech Questions
    Last Post: 08-25-2009, 08:54 PM
  3. Cold Air intake bad for your engine because of dirt entering?
    By 04tahoez71 in forum Performance & Fuel
    Last Post: 01-17-2009, 04:30 PM
  4. 03' Envoy Check Engine Light on after COLD start
    By dacraig in forum Chevy Trailblazer Forum (GMC Envoy)
    Last Post: 01-11-2007, 05:07 PM
  5. engine light comes on when cold outside [Expired Topic]
    By jimmmmm in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 11-02-2006, 04:07 PM
