    Question Cleaning Black Diamond Plate Toolbox
    Any suggestions on how I can clean my tool box? You can't really see the build up past the pollen in the picture. But it's got a white film across the top. Click image for larger version.
    I would pour some simple green on it and then go at it with a stiff brush
    Sounds like someone applied wax to it and let it dry?
    Apply Simple Green when not in direct sunlight (so it wont' dry out quickly), wait 3-5 mins, and like Pikey said -- use a brush. If that doesn't do it then try 3M Adhesive, Tar and Wax Remover.
    Ha! Caught...
    Aside from the white film the finish was starting to look dull too. That's why I tried waxing it.. I failed. Got some mean green last night, gonna give it a try. Thanks for the advice fellas.
    if the box is not too old I would return it . the powder coat must be defective. the alum box requires a coating to prevent the alum from corroding . using acid cleaners/ strong cleaning agents will attack the finish.
    the alum will then turn white powdery as it corrodes.
    soap, water, dry, then a sponge with wd-40 followed with a dry towel. works great.
    Thanks for all the input guys. I tested out a spot with mean green and it worked. It took away the white film and shined it up a little.
  1. painting over diamond plate aluminum ?
    By RATRODKING in forum Chevy Truck Talk & GM News
    Last: 03-29-2012, 03:14 AM
  2. Trade Wtt- aluminum diamond plate tool box for black
    By db3812 in forum General Classifieds
    Last: 01-13-2012, 08:51 PM
  3. Where to find Diamond plate tailgate cap for my 2006?
    By AnimalYates in forum Chevy Truck Accessories
    Last: 08-12-2011, 11:07 PM
  4. Ultima Diamond Plate Bed Tool Box
    By 06piney in forum General Classifieds
    Last: 11-16-2009, 08:38 AM
  5. Can't find diamond plate tailgate cap!
    By kylegillean in forum Chevy Truck Accessories
    Last: 10-06-2009, 10:04 AM
