    Default 01 savana starts then stalls
    hello. i have a 2001 gmc savana and i had it parked for 5 days and when i went to try to start it, all the cluster gauges maxed out, and it just starts and stalls. the security light is not on. i had it at the dealer for 2 weeks .here is what i changed so far. fuel pump, fuel injectors, distrubutor,sparkplugs, cranksensor, upper intake gaskets,and lower intake gasket and apperently my pcm is good. i was told by the dealer that they couldnt figure it out. just wondering if any1 had issues like this.
    Welcome To GMTC! I would hate to see your bill at the dealer right now! I don't have any ideas at the moment, I am sure someone will come along soon.
    Well, after we get the problem fixed, I think a "Small Claims" court procedure would be in order.
    A totally incompetent approach to solving your problem.
    Usually, a starts and then stalls problem is almost always fuel related.
    You have a new pump (which you didn't need), but is the filter clean; is the fuel pump relay good?
    As I said above, fuel is almost always the problem, the other is the ability for the engine to get rid of the exhaust. Is the exhaust clear and able to breath. Is the muffler good, how about the cat(s)?
    It would stink if you had all that replaced and an animal decided to make a nest in the exhaust pipe causing a blockage.
    I agree i wasnt happy with their service all they were doing was calling parts that were not needed. Ok soo a new fuel filter was put in by the dealer. I replaced the cat about 4 months ago. But i can disconnect pipe and try it. And i also put a new pump relay.
    Ok i disconnected the converter and that still didnt help. Any other ideas?
    this is a stab in the dark, but maybe an egr valve? that is a fairly typical problem with other vehicles that start and stall.
    I also would not pay for those parts, or do the small claims thing. That is pretty ridiculous they are just throwing parts in.
  1. Replies: 8
    Last Post: 05-14-2012, 04:34 PM
  2. 95 1500 w/t starts & stalls immediately.
    By Dgbebop in forum Chevy C/K Truck Forum
    Last Post: 12-23-2011, 08:52 PM
  3. TBI starts then stalls, gas held slowly stalls
    By TigerZ in forum Chevy C/K Truck Forum
    Last Post: 09-02-2008, 02:27 PM
  4. hard starts and stalls
    By leother in forum GM Powertrain
    Last Post: 09-26-2007, 09:29 AM
  5. Starts but Stalls out
    By mcrich in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 04-09-2007, 09:36 AM
