Results 1 to 9 of 9
    Default 2011 Silverado - Noise from rear end while turning and hitting a bump
    I have a 2011 Silverado with 14,xxx miles. I recently took it in to my local Chevy dealer for a noise that developed in the rear end. The noise is a sort of banging noise when going over a bump with the front wheels turned. I most notice it when backing out of my driveway, as it has the usual low curb that most subdivisions have. The dealer told me that it was a normal noise caused by the rear axle shaft shifting and hitting the axle retaining pins. I don't think that is normal, and it never did it until recently.
    Any ideas?
    wouldnt know without hearing and seeing it. do you have a hitch with a reciver in? those can causes noises over bumps.
    Quote Originally Posted by dprince48 View Post
    Any ideas?
    Do you have the G80 differential?
    I disagree, my 2008 and 2013 never made a banging noise when I made turns or hitting bumps.
    Now my 2008 made a clunking noise when the locking differential mechanism engaged when I first got it. GM apparently put the wrong fluid in there and simply replaced the fluid.
    Mods:
    Advent OGM1 Navigation
    Airaid MIT
    EGR Rail Caps
    K&N Air Filter
    Flowsound 40 Muffler
    Chrome Tailgate Handle Cover
    TonnoPro HF-155 Tonneau Cover
    have you removed the rear diff cover and replaced the diff gear oil and clean yet ? this should be done after 2,ooomiles of use when new.
    gears need inspecting for proper meshing and any abnormal wear teeth cracks damage etc.
    if the vehicle was used to tow or haul heavy loads first 2000miles this does cause issues with the G80 diff.
    2000 miles?? change even before the engine oil?? I can understand wanting to get the "break-in" oil out but I think 2k miles is a little soon. Regardless if this was done or not it still should not be making any abnormal noises that was not heard all along.
    Did you check the "U" bolts over the axle for the proper torque?
    I had a problem similar to that right after I removed the rear 1" blocks, correctly torquing the bolts solved it.
    i have the same problem dealer said it was normal
    Sr. Apprentice LURCH's Avatar
    Aug 2011
    North East Tn.
    Any ideas?
    My 2011 makes a noise and best I can tell its the spare tire. It has a spring on it I guess so you can't over tighten it. I let all the air out of it then tightened it up and put air back in it and it helped some but it's still there. I've had it on a lift and checked everything thats all I could find.
    Apr 2011
    Toronto,Ontario
    Any ideas?
    I had the same problem and someone on here told me there was a tbs for the rear springs, took it in to my dealer no more problem. I will say that it is starting to come back. Here is the tsb for the springs, #06-03-09-004d. Hope that helps you like it did my truck.
  1. front end making chattering noise when hitting bumps.
    By jwzobel2 in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 11-30-2012, 01:43 PM
  2. Odd noise when turning/braking.
    By Sierraowner5.3 in forum Lifted & Offroad Suspension
    Last Post: 09-22-2011, 11:22 AM
  3. noise when turning left
    By bigrob in forum Lifted & Offroad Suspension
    Last Post: 07-19-2011, 10:45 AM
  4. Popping noise when Turning wheel
    By Z71silverado in forum General Chevy & GM Tech Questions
    Last Post: 09-23-2010, 09:02 PM
  5. Vibration noise when turning right only
    By goatruckman in forum Lifted & Offroad Suspension
    Last Post: 06-13-2010, 07:57 PM
