    Question reduced engine power
    2006 silverado 4.8 getting reduced engine power message and I have to start approx 3-4 times to make message go away to drive and check engine light comes on and goes out after a short period and I can never get the code. Could this be the tps and is there a way to rectify this problem? Thank you for any help I have 171,000 miles and treat her like a baby!!
    Check the wires at the throttle body. pull each wire individually and see if there is a bad connection.
    Quote Originally Posted by alw View Post
    Thank you I will try it.
  1. Reduced engine power
    By Chris_ce in forum GM Powertrain
    Last: 12-23-2011, 09:47 AM
  2. Reduced engine power help
    By NHRASST1974 in forum General Chevy & GM Tech Questions
    Last: 05-10-2010, 12:41 PM
  3. Reduced engine power
    By stuntworks in forum GM Powertrain
    Last: 01-11-2010, 07:56 AM
  4. reduced engine power
    By millerahf in forum GM Powertrain
    Last: 06-02-2009, 12:28 PM
  5. reduced engine power
    By bisskits in forum The Coffee Shop ~ Chit Chat
    Last: 09-29-2008, 08:54 AM
