GM Truck Club
Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
  1. #21
    Sr. Engineer FergusonT's Avatar
    May 2010
    Southwest Michigan
    Yeah, a very poorly installed remote start wiring job. When I was under there looking for the flasher relay I noticed everything was a cluster mess. Nothing was mounted where it was supposed to be, everything was just loose, wires everywhere.
    I really wish I would have had time to work on it myself so I could get some experience doing that kind of work.
    1999 Chevrolet Suburban LS K1500
    1991 Chevrolet S10 4.3L 4x4
    2005 Suzuki Forenza (GM/Daewoo)
  2. #22
    Legend
    Sep 2010
    everett, massachusetts
    I guess you did the correct thing by having , that shop fix up the hacked wiring. not a job for learning.
    with what you stated on the condition , this needs time to make right.
    many of these alarms/remote starts create many owner issues with this type install which is very common being screwed up.
    good luck .
  3. #23
    May 2010
    Southwest Michigan
    Your probably right.
  4. #24
    May 2010
    Southwest Michigan
    So far in the past few months this truck has had the fuel pump/filter, plugs/wires, intake gaskets, alternator, ignition switch, ignition lock cylinder housing, fuel pressure regulator, battery........I also have an upper ball joint and front shocks to install...oh and a new fog light to install......and replace the multifunction switch (no turn signals/flashers-already replaced the flasher relay). hm what else. I really should do a new slip yoke because of the annoying clunk.
Similar Threads
  1. Passlock relearn
    By conman13 in forum GM Electrical Tech
    Last Post: 09-29-2011, 06:41 PM
  2. Please, NEED HELP ASAP, gm passlock?
    By jaden5012 in forum General Chevy & GM Tech Questions
    Last Post: 02-18-2011, 12:14 PM
  3. 04 Colorado passlock/no start
    By nj110 in forum Chevy Colorado Forum (GMC Canyon)
    Last Post: 05-24-2010, 06:09 AM
  4. Passlock
    By aboston in forum GM Electrical Tech
    Last Post: 01-05-2010, 05:49 PM
  5. does the Passlock II do this
    By EdPDX in forum General Chevy & GM Tech Questions
    Last Post: 01-06-2009, 09:51 AM
