    Default Fuel Line Disconnect Tool Size???
    Hi there. My 04 Suburban has the stupid 0327 Knock Sensor Code for Bank 1. I've turned it off a couple of times, but it comes right back. So I'll be replacing both of the knock sensors this weekend.
    Here's my question. What size fuel line disconnect tool do I need for the inlet and outlet lines to the fuel rails? 3/8? Any brand recommendations?
    Thanks
    KP
    It is metric, I bought my fuel line disconnect tool from harbor freight for $1.97, perfect fit for the new car fuel lines. I used it on several, and they haven't broken yet. It has 4 different sizes, 2 metric and 2 standard for older cars.
    Cool, thanks. Headed to Harbor Freight.
    Curious why you need to remove the fuel line to change the knock sensors. Aren't they completely external and mounted on the lower portion of the block?
    His suburban has an ls based engine, most likely the 5.3. To change the knock sensors requires removing the intake manifold/fuel rail combo. The knock sensors are under the intake, in two recessed pockets of the valley cover. Screwy setup, but at least it's a dry intake..
    Oh, I see. It's like the original Gen III LS1 setup. Are all the Gen III Vortecs that way, or did some of the later ones have the sensors mounted on the sides of the block, like the Gen IV are?
  1. 2002 Suburban Fuel line damaged where it hooks to fuel filter, any way to fix?
    By pelletman in forum Chevy SUV & Crossover Tech Forum
    Last: 07-11-2012, 06:50 PM
  2. 02 Yukon SLT 5.3L Flex Fuel, fuel line issue
    By TRyan9441 in forum Chevy Tahoe Forum (GMC Yukon, Cadillac Escalade)
    Last: 06-02-2011, 12:19 PM
  3. o2 Sensor tool size???
    By SoundZman in forum Performance & Fuel
    Last: 09-18-2010, 03:54 PM
  4. fuel line
    By sargentmuttly in forum Performance & Fuel
    Last: 09-16-2010, 10:59 AM
  5. 96 Sub rear brake line fitting size
    By DMAXX2007 in forum Lifted & Offroad Suspension
    Last: 04-14-2008, 12:37 AM
