Results 1 to 10 of 11
    Default Pulling Hard Left in 4x4
    Hey guys, Im really hoping to find some help here as I am at a complete loss. I've got an 05 Z71 Sierra that humms quites loudly and pulls hard to the left the second that 4 wheel drive engages and then any and all hints to the problem disappear the second it's returned to 2wd. I've replaced both hubs, rotors, and pads(Before problem) and then today I replaced both CV's(Problem related) which had no affect on the condition.
    Thank you for your time,
    -Rob
    EDIT: Someone told me it could be the transfer case chain, but that makes no sense in my logic.
    I have sometimes seen this kind of behavior when there is excess "tension" in the drivetrain. Are all 4 tires matched, or are the fronts a different make/model from the rear? Even tires that are the same size can have enough size difference from manufacturer to manufacturer to create tension that can show up as a pulling to one side.
    You know what? The Spare is actually on the right front, same brand and model (Bridgestone Duelers but the others are Revos, the spare wasn't) but I do believe the load range and speed rating was different on the spare. Ill try swaping them around to see if the problem transfers to the other side tomorrow morning.
    Thank you!
    -Rob
    According to my ring and pinion guy, The bearing on the drivers side of the front diff are known to go bad at about 100,000 miles. He said that this is the most common repair he sees. Take it by a gear shop, they should check it out for free. Most the time transfercase chains just become noisy, a Bad one will not cause pulling..ever...
    with the operation of 4wd all tires must be the same size and wear. when this is NOT then the drive train will fail .
    with a spare unworn tire on the passenger side and worn tire on the driver side it would do a pull to the left.
    I have this same issue with my 2000 GMC Sierra Z-71. I have replaced the front differential, both CV axles, the driver side wheel hub, and all of my tires are the same size. Wheels are not bent, breaks are relatively new etc. I haven't found any real answers searching the web for almost 6 months. It will pull to the left in 4wd, even in snow or mud, and then as soon as you take it back to 2wd it pulls straight instantly. Any answers on this issue?
    swap the front tires left to right right to left.
    Last Post: 10-29-2012, 05:10 AM
  2. 4wd pulls hard to the left
    By fender_fan969 in forum GM Powertrain
    Last Post: 02-03-2011, 04:10 PM
  3. Help!!! Hard left turn
    By disturbedvn in forum GM Powertrain
    Last Post: 07-29-2010, 05:41 PM
  4. 02 Yukon XL Denali pulling hard to the right.
    By jdkebuggy in forum Lifted & Offroad Suspension
    Last Post: 01-04-2010, 06:36 AM
  5. 93 suburban 4x4 pulls to left hard
    By vintage_car in forum General Chevy & GM Tech Questions
    Last Post: 10-25-2009, 03:44 PM
