    Smile how much fluid a 4l60e holds
    Tues morning I am thinking about changing my trans fluid & filter ,The trans in my 98 k 1500 is a 4l60e with a deep pan & i need to know how much it hold any info will be thankfull
    crazyforgms
    5 quarts for a fluid and filter change.
    I have a 4l60e, and a derale deep pan and my pan holds an extra 3 quarts, so for me it would be 8 quarts.
    11 quarts for a complete flush
    Today I change the trans oil & filter in old blue.It was not bad job I took my time the only problem I had was when I went to bolt the trans pan on the shield that bolts to the side of the trans between the exhaust was in the way.once i unbolted the shield the pan bolt right back up.I put 4 Quarts new dex 3 & some lucas trans fix in the old girl goes right the gears great . thanks for the info
    crazyforgms
  1. 4L60E tranny fluid blow-by issue
    By SurrealOne in forum GM Powertrain
    Last: 10-03-2012, 08:14 PM
  2. 4L60E Rebuild Leaking Fluid in OD
    By BMason in forum GM Powertrain
    Last: 06-19-2012, 04:39 PM
  3. Replies: 2
    Last: 09-04-2010, 08:39 PM
  4. Best fluid/filter for the 4l60e?
    By idowa in forum GM Powertrain
    Last: 08-27-2010, 07:49 PM
  5. 4L60E loosing Fluid. But not on the ground HELP!
    By murdog94 in forum GM Powertrain
    Last: 08-27-2010, 02:31 PM
